Use of dielectric grease
Old Jul 17, 2007 | 09:50 AM
philpsu's Avatar
Default Use of dielectric grease (spark plugs & distributor)
Do you apply dielectric grease when you change your plug wires and distributor cap? I will be changing the plugs, wires, distributor and rotor on my gf 98 civic soon and was curious.
Modified by philpsu at 11:16 AM 7/17/2007
Old Jul 17, 2007 | 11:28 AM
thesmogman's Avatar
Default Re: Use of dielectric grease (philpsu)
I do. I got really pissed off that when I went to change the plug's and pulled off the clips from the wires to the plugs.
So I use it on everything from cap to plugs, top of rotor, and even battery posts.
No more oxidation for me.
Do yourself a favor and also get anti-seize for your plug threads. I use this on lugnuts, O2 sensors, and exhaust bolts. Keeps them from rusting.
Two good tool's that are not really tools.
Old Jul 17, 2007 | 11:32 AM
philpsu's Avatar
You never see any mention of using the grease in any of the how to guides. I would think that would be a good tip.
Old Jul 17, 2007 | 12:35 PM
thesmogman's Avatar
Default Re: (philpsu)
Sometimes when you buy a new cap and rotor they provide a little "pill" with
di-grease in it but they don't tell you where to put it.
Put a dab on the top of the rotor where the cap button touches the rotor, and I lightly coated the button from the coil to the cap too.
I guess it is an ancient Chinese/mechanic secret
Old Jul 17, 2007 | 01:25 PM
blk2mid2sol's Avatar
usually the instructions are on the back of the casing.... i also use dielectric grease for my weather strips helps maintain the rubber and quiets the squeks
forgot to mention yes its a good idea to use on your spark plugs/wires
Old Jul 17, 2007 | 05:08 PM
sick CD7's Avatar
Default Re: (blk2mid2sol)
on kia cars the dielectric greese cuased short circuits in certain plugs it was a tsb so be careful when using the greese on everything ie sensitve plugs
Frost7177
15
Mar 6, 2009 04:18 PM
577HondaPrelude
Feb 20, 2004 09:52 AM
Kamin
Jul 31, 2003 07:45 AM
tegon-gsr
May 18, 2003 09:41 AM
