h22a swap help
Old Jul 16, 2007 | 08:51 PM
Honda Sport's Avatar
Default h22a swap help
scenario: I have a h22a swap in an 94 EX coupe. reused the EX harness. basically everything hooked up. thing is, when I turn the key to the on position, all I get is the SRS light and hand brake light on(when the ebrake is up). can't hear the main relay click on. I know the MIL and other lights are supposed to come on for a few secs and turn off but it's not happening. I put a new battery in, triple checked all the fuses. backup fuse, ECU fuse, etc are all good.
I'm thinking this might be a grounding issue. thing is, I only have the thermostat ground on at this point. what other grounds am I missing? anything else I'm overlooking? TIA!
Old Jul 17, 2007 | 10:18 AM
pcguy760's Avatar
Default Re: h22a swap help (Honda Sport)
I would make sure the chassis ground is on first before the thermostat ground (although that is important too) - personally I think that the chassis/body number one priority ground - alot of stuff rely on a chassis ground. Try running a good size wire from the battery negative to a bolt on the chassis near the battery, etc...
Old Jul 17, 2007 | 11:04 AM
JasonST's Avatar
Default Re: h22a swap help (pcguy760)
U need the valve cover/head ground, thermostat, starter ground, and ecu ground. U need all these grounds for the car to start and run properly.
Old Jul 17, 2007 | 01:09 PM
Default Re: h22a swap help (JasonST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonST &raquo;</TD></TR><TR><TD CLASS="quote">U need the valve cover/head ground, thermostat, starter ground, and ecu ground. U need all these grounds for the car to start and run properly.</TD></TR></TABLE>
where's the starter ground go to and where's the ecu ground? my bad for being stupid right now, half asleep at work smelling like alcohol.
Old Jul 17, 2007 | 07:42 PM
JasonST's Avatar
Starter ground is on the starter, obviously, but more specifically it should come out of the wiring harness and slide and lock onto a small altch on the starter, if ur wiring harness doens't have it u might have to wire it up seperately, but look on the starter and u'll see what i mean and where it is. The ecu ground is a small ground that goes from the wiring harness onto the bottom of the throttle body, if ur harness doesn't have it u might have to wire it up seperately too.
Old Jul 28, 2007 | 03:58 PM
stupid me, it was the grounds. I guess I was rushing things a lil too much. but anyways, I put on the valve cover ground and the tranny ground and everything started right up.
brian8702
Aug 15, 2010 10:02 PM
brian8702
Aug 15, 2010 01:06 PM
dillon410021
Jun 18, 2009 10:06 AM
D15Bbigred
34
Oct 6, 2005 03:50 PM
coot_er
May 18, 2004 01:19 PM
