Why do I keep blowing the battery fuse?
Old 06-18-2009, 05:38 AM
dillon410021's Avatar
Icon2 Why do I keep blowing the battery fuse?
The battery fuse on my 1996 civic ex with a d16y8 keeps blowing. I have added new ground cables:
-intake mani to chassis
-chassis to trans
-chassis to alternator ground
-chassis to valve cover
-chassis to starter ground.
It will blow the fuse as soon as you hook the battery up.
I did put the harness on and the computer in.
what could be the problem?
thanks
Old 06-18-2009, 05:56 AM
civic_driver's Avatar
Default Re: Why do I keep blowing the battery fuse?
The battery cables are probably shorting somewhere. Check the power cables, not just the ground cables.
Old 06-18-2009, 06:18 AM
Utzz's Avatar
So your battery fuse (the 80A one?) kept blowing and you added more grounds to try and fix the problem?
Step 1: Remove any ground cables that weren't there from the factory.
Step 2: For the factory ground cables, remove them and sand down the mating surfaces of the chassis and eyelet, wire wheel the bolt to remove any corrosion and re-assemble.
Even if you didn't add those grounds in an attempt to fix this, remove them anyway. Ground loops are a bad thing. Get the ETM (electrical troubleshooting manual) for your car, disconnect stuff that the fuse is powering and find that short.
Old 06-18-2009, 06:27 AM
Former User's Avatar
Or is 40A fuse 42 blowing? If so, start by unplugging the two connectors to the ignition switch to see whether this stops the fuse from blowing.
Old 06-18-2009, 06:43 AM
it is the 80A battery fuse
so (T101) is just a cable fro the fuse box to the alternator. If so, I will run a wire directly and see what happens. That is probably my problem.
Old 06-18-2009, 08:01 AM
97twodoor's Avatar
Are you sure you did'nt put a ground directly where the alternator B+ output is?
Old 06-18-2009, 10:06 AM
I think thats my problem
thanks
tjman982002
08-02-2012 12:51 PM
toner297
Honda Civic (2001 - 2005)
12
05-24-2011 12:39 AM
Tip14
12-27-2007 01:13 PM
Ruben19
10-10-2007 08:49 AM
DiSbaDbOi
16
01-05-2005 07:24 PM
Quick Reply: Why do I keep blowing the battery fuse?
