Suggestions about getting a broken bolt out
Old Jul 16, 2007 | 06:38 PM
Nisif's Avatar
Default Suggestions about getting a broken bolt out
The bolt that connects the external wastegate flange to my turbo manifold backed out and broke off flush with the turbo manifold. I drilled a hole in the center of the broken bolt than tried using an easy-out with no luck.
I decided to use a tap on the broken bolt's hole instead. I've had luck with this in the past, usually the tap will dig into the broken bolt placing a better grip on it, then as you back the tap out counter-clockwise the broken bolt comes out along with it.
Unfortunately the tap broke off inside the broken bolt. The only option I was left with is to drill out the broken bolt and oversize the original threaded hole in the turbo manifold. It's not working, I tried drilling on it with a colbolt drill bit (stronger than titanium) for 15 minutes but it won't penetrate through the broken tap's material.
What can I do? Would a machine shop have a drill press that will penetrate through it? TIA
Old Jul 16, 2007 | 07:16 PM
builthatch's Avatar
MiG-21 superfan
Default Re: Suggestions about getting a broken bolt out (Nisif)
good machine shop FTW; that's part of what they do.
they should be upfront about what they will try and if they think they can handle it.
Old Jul 16, 2007 | 07:28 PM
Nisif's Avatar
Default Re: Suggestions about getting a broken bolt out (builthatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by builthatch &raquo;</TD></TR><TR><TD CLASS="quote">good machine shop FTW; that's part of what they do.
they should be upfront about what they will try and if they think they can handle it.</TD></TR></TABLE>
That's reassuring, I'll give them a call in the morning, thanks
Old Jul 16, 2007 | 07:37 PM
builthatch's Avatar
MiG-21 superfan
i've been in your situation many a time and have ended up at the machine shop. the good thing is if they do hack it up a bit, they typically are pretty good at getting it back on track with heli-coils, welding, etc...
Old Jul 16, 2007 | 07:48 PM
Nisif's Avatar
Good deal, what kind of price range should I expect? I'd rather just have them overbore the hole and then I can tap it after they're done.
DCRB
13
Mar 23, 2010 09:47 AM
theauthor17
Aug 8, 2008 11:47 AM
Speed94
Aug 1, 2008 06:35 AM
tyflip2
Jan 29, 2004 05:04 PM
rextec
Dec 11, 2003 05:56 AM
