Please Help with b20b basemap..
I'm needing a basemap for my obd1 b20b.. I'm using crome v 1.4.5
Could i use just a stock LS map.. What differences are there?
When i go to create a new map.. i don't have a b18b1 as an option..
any help/ insight is appriciated..
thanks in advance
thanks in advance
Check this out
http://forum.pgmfi.org/viewtopic.php?t=14257
The b20 will probaby want a little more fuel as it makes more Tq, timing may be a little different because of the increased bore, I'm assuming this is a stock build. If you can't get a b20 map the Ls would be a good starting point, to do it right you need to tune on a dyno.
Good luck
Good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer »</TD></TR><TR><TD CLASS="quote">Whats your email? I have one.</TD></TR></TABLE>
cool man.. my email is werdjimmy@comcast.net.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pasaunde »</TD></TR><TR><TD CLASS="quote">Merry Xmas
http://web.archive.org/web/200...Codes</TD></TR></TABLE>
I found a b20 basemap on there, but it's obd2
yes it is a stock b20.. i/h/e.. I'm just wanting to get the best gas mileage/performance.. witout having to hit up the dyno
