new ignitor, no spark, 1990 accord
Old Jul 14, 2007 | 05:06 PM
jimbo090757's Avatar
Default new ignitor, no spark, 1990 accord
I changed the ignitor on my accord, it tested bad, i changed the rotor, and spark plug wires, no spark to the plugs. I put a meter on the coil, it tested good. Please Help!
Old Jul 14, 2007 | 08:12 PM
hondadude's Avatar
Default Re: new ignitor, no spark, 1990 accord (jimbo090757)
First check for power to the Black/yellow wire at the dist. with the key on, that proves power thru the ignition switch.
I've seen lots of times the coil will ohm good, but short under load.
Old Jul 17, 2007 | 01:00 PM
Default Re: new ignitor, no spark, 1990 accord (hondadude)
bought new coil, no dice
what is the next step
Modified by jimbo090757 at 2:47 PM 7/17/2007
Old Jul 17, 2007 | 03:05 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Here is a good guide on items to check and troubleshoot:
http://techauto.bravehost.com/
Old Jul 18, 2007 | 04:42 PM
Default Re: (tech8)
Its working! the trouble shooting flow chart pointed to the ECU ground at the thermostat Thanks for that website
Old Nov 27, 2007 | 07:09 AM
budomove's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">First check for power to the Black/yellow wire at the dist. with the key on, that proves power thru the ignition switch.
I've seen lots of times the coil will ohm good, but short under load.</TD></TR></TABLE>
I ran my 91 std with the dizzy plug bracket unbolted, and lying on the tranny near the thermostat after replacing the dizzy o ring, could this cause a short?
Having an unhooked valve cover ground (the smaller of two wires that bolts to the em or block)?
The car would sputter under load, and stalled a few times, once while coasting to a stop, and once while on the gas I believe. The first time I restarted it after 15 minutes of fiddling with the dizzy front to back, but maybe it just needed to cool.
The second time I adjusted the dizzy while friend cranked and no dice, just kept cranking.
tested the wires and determined no spark, then un bolted the dizzy, slipped it off the camshaft then popped it back in place and on the first crank it started right up.
Car has not stalled since I popped the dizzy off and put back on, two days ago, and I then had the timing set by gun the next day by the mechanic who said it was barely off.
I replaced ignitor with exact same nec ignitor from junkyard, and the car seemed to idle lower and smoother immediately.
I had also just replaced a rubber plug that had been temporarily plugging a valve cover hole where I'd snapped the valve cover bolt, so maybe it was a vaccum leak that accounted for the idle, although the rubber plug had a decent seal I think.
Thanks in Advance for any help!
frank
Modified by budomove at 3:24 PM 11/27/2007
gtibbetts
Oct 18, 2016 03:39 PM
honda_lx
Mar 26, 2014 01:04 PM
LOLO93PRELUDE
May 24, 2008 02:10 PM
eric416
May 11, 2007 03:54 PM
BOMBCRU
Dec 9, 2004 11:30 PM
