Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
GLOW GAUGES HELP INSTALL
Old Jul 13, 2007 | 08:57 AM
firetyphoon1's Avatar
Default NEW GLOW GAUGES NEED HELP TO INSTALL!!
I just got my glow gauges from ebay and theres no instructions... 2001 Civic Sedan. LX, can any one help me on this???
Modified by firetyphoon1 at 1:15 PM 7/13/2007
Old Jul 13, 2007 | 09:41 AM
Todd00's Avatar
I said I don't want a title!
Default Re: NEW GLOW GAUGES NEED HELP TO INSTALL!! (firetyphoon1)
https://honda-tech.com/zerothread/1878593
Also, did you try searching?
Old Aug 6, 2007 | 07:08 PM
yea i searched, no step by step explanation
Old Aug 7, 2007 | 04:07 AM
daddy's Avatar
i installed some on my friends pontiac. its been a while tho so my memory is a bit rusty. once you plug all the guages together how many extra wires do you have?
Old Aug 7, 2007 | 11:06 AM
daddy's Avatar
Default Re: NEW GLOW GAUGES NEED HELP TO INSTALL!! (03turboem2)
1.THe first thing you need to do is take a picture of your gauge cluster or sketch where the needles are so in case you have to remove them you can put them back on correctly.
2. then remove the trim around your current gauge cluster and pull it out. then pull the plastic off the front.
3. now if your gauges come with adhesive use it and slip the new gauge face over the needle or pull the needle off adn place the gauge face on. be careful to line it up correctly. if you dotn have adhesive with it i used a glue stick because on the pontiac i installed them on the plastic actually helped hold the gauge face in place. make sure you run the wires down so you can connect them underneath later!
4. repeat step 3 for all the gauges
5. put the clear plastic back on adn fish the wires down into the dash adn mounth the whole gauge cluster back in the dash.
6. now find a place to mount the little black box under the dash and plug all of the wires from the gauges into each other/into the little black box so now you should have the wire runnign to the dimmer **** which then continues on to power and a ground wire.
7. find a power source. a fuse that is only hot when the key is on or better yet only when the headlights are on is best. tap your hot wire into the fuse using an 'ad-a-circuit' or by splicing into the current wire coming off the fuse.
8. now find a good ground. usually stuff like the brackets around the steering column. or bots in the firewall work well cuz they are grounded to the chassis.
i think that should do it for ya. if you have any questions or problems i'll try to help you out!
Old Aug 8, 2007 | 06:55 AM
wow thanks for the help!, i have some info from other sources so lets see it if all works out!
Old Aug 8, 2007 | 07:35 AM
daddy's Avatar
hopefully it does! keep me posted!
Old Aug 12, 2007 | 07:35 PM
yea i will, actually i took out the needles and put the new gauges over the old ones b/c it wasn't stable.
Then i started the car with the new gauges (didnt install the wiring just yet) just to check everything out.
Some needles get stuck, ex: the rpm just goes up the when going down to 1 it stops at 3 but if i push the gauge face down just enought it will slide back with ease. i put adhesive but the gauge is sticking out a lil bit, btw how much does caliboration cost... lol.... X(
Old Sep 7, 2007 | 09:27 PM
Yooo i got them in but umm read my other post now.....
totsie7944
Apr 21, 2008 01:10 PM
aznvi3tkidz
Sep 7, 2005 02:32 PM
nocturnaldragon
23
May 3, 2004 03:01 PM
rkn527
Feb 18, 2003 08:18 AM
loki2323
Jul 6, 2002 07:32 PM
