Coming Out Of 2nd
Old Jul 12, 2007 | 02:41 PM
`chrisb's Avatar
Default Coming Out Of 2nd
Ok, I'll be slowing down to make a left turn, probably only goin 20km/h or less.. Its in a second gear and it pops right out. That mean my tranny is pretty much dead ? haha
Old Jul 12, 2007 | 02:43 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: Coming Out Of 2nd (`chrisb)
Yep, thats never really a good thing. My friends car used to have a tranny so bad you wouldnt need to engage the clutch to change gears. lol
Old Jul 12, 2007 | 02:54 PM
quapouh's Avatar
if that happened on the turn could be associated with worn motor and tranny mounts ... pop the hood and rev the engine few times ... look if it jerks, look for broken or cracked rubber on the mounts ... From what you said it happened first time ... might not be a tragedy yet ...
Old Jul 12, 2007 | 03:02 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: Coming Out Of 2nd (quapouh)
If it was only once then I wouldnt sweat it. I would do what quapouh reccomends such as checking for bad mounts and what not. If the car is old and hasnt had a tranny flush in a while id reccomend doing that too.
Old Jul 12, 2007 | 03:10 PM
slowcivic2k's Avatar
Default Re: Coming Out Of 2nd (5_Lug_B)
ISB failure, push the clutch in and hold it for 5 secs at idle, and then let it out all the way, and note any pitch that the transmission produces to confirm that.
30-40 bucks in parts will be needed, a new ISB, new ISB seal is all that is needed, but I would replace all the seals, and inspect all the other bearings as well. Gonna need some brake cleaner to clean all that metal out of the case.
Old Jul 12, 2007 | 05:10 PM
97Ej6mike's Avatar
Default Re: Coming Out Of 2nd (slowcivic2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">ISB failure, push the clutch in and hold it for 5 secs at idle, and then let it out all the way, and note any pitch that the transmission produces to confirm that.
30-40 bucks in parts will be needed, a new ISB, new ISB seal is all that is needed, but I would replace all the seals, and inspect all the other bearings as well. Gonna need some brake cleaner to clean all that metal out of the case.</TD></TR></TABLE>
You heard it, from Dr. Transmission himself, lol.
Any pics or DIY writeups to go by for those who havent taken their tranny apart before?
Old Jul 12, 2007 | 05:13 PM
Default Re: Coming Out Of 2nd (97Ej6mike)
Here is one on another forum, but its a D-series gearbox, but its basically the same as a B-series, I'll be doing a writeup on a B-series and D-series as soon as I can find my camera....
http://www.d-series.org/forums...14079
Old Jul 13, 2007 | 07:55 AM
97Ej6mike's Avatar
Wow thats a great writeup.
.joseph
Feb 28, 2006 06:13 PM
RC_SKUBY
Aug 11, 2004 11:37 AM
RacerSi
19
Jan 7, 2004 12:15 PM
2000Accord5sp
Dec 24, 2003 10:30 AM
MattGSR
Mar 22, 2002 10:56 PM
