Oil Filter Q...quick help...
Old Jul 12, 2007 | 11:25 AM
The Collin's Avatar
Default Oil Filter Q...quick help...
I've heard it's best to change the oil using Genuine Honda filter's, and if not done with a honda filter, that VTEC won't engage after a while, or it will damage the engine itself in the long run, is this true? someone enlighten me, as i'm about to change the oil again, and can get other filter's for alot less. Thanks!
Old Jul 12, 2007 | 11:27 AM
bryce-o's Avatar
Default Re: Oil Filter Q...quick help... (99_hb_on_air)
any oil filter will work, although k&n, honda, or mobil one tend to be better. no matter what filter you use, its not going to disrupt vtec or harm the engine, as long as the filter is correct and installed right.
Old Jul 12, 2007 | 11:30 AM
818dc5's Avatar
i've use mobil 1 filter for about a year now. no problems. i believe it has nothing to do with vtec engaging. filter is just a filter, just make sure you get the correct filter for your car. vtec wont engage if u have low oil and will cause damage.
Old Jul 12, 2007 | 11:39 AM
The Collin's Avatar
Nice, thanks.
Old Jul 12, 2007 | 12:58 PM
eMpAtHy's Avatar
Default Re: Oil Filter Q...quick help... (818dc5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 818dc5 &raquo;</TD></TR><TR><TD CLASS="quote">i've use mobil 1 filter for about a year now. no problems. i believe it has nothing to do with vtec engaging. filter is just a filter, just make sure you get the correct filter for your car. vtec wont engage if u have low oil and will cause damage.</TD></TR></TABLE>
u dont even have to use the correct oil filter. some people have used "oversized" filters for their cars. I dont know if it has been done in detail with the rsx or not, but for the H series engines, i remember people using really big oil filters.
It will lower oil pressure by a little and because the filter is bigger, you will have to add slightly more oil.
As for me, i've been using the honda oem s2000 filter and mobil 1 5w30 for every oil change of my car and i haven't had a problem with oil leaking out of the filter or anything.
Old Jul 12, 2007 | 02:10 PM
hawaiiancb74's Avatar
Default Re: Oil Filter Q...quick help... (eMpAtHy)
or use smaller ones... i use hamp filters.. and im not a fan of honda filters unless they are toyo roki.. no filter ide say should hinder the performance of your vtec over time ..
Old Jul 13, 2007 | 10:41 PM
thrty8street's Avatar
Default Re: Oil Filter Q...quick help... (hawaiiancb74)
whats the difference with the s2000 oil filter and the reg honda oil filters? Do the s2000 filters cost more? If so how much?
Old Jul 15, 2007 | 11:04 PM
johnclaunch's Avatar
Use HAMP filters. They are a copy of the Japanese Honda OEM filters (much better construction than the US OEM counterparts.)
Old Jul 16, 2007 | 09:37 AM
Default Re: Oil Filter Q...quick help... (thrty8street)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street &raquo;</TD></TR><TR><TD CLASS="quote">whats the difference with the s2000 oil filter and the reg honda oil filters? Do the s2000 filters cost more? If so how much?</TD></TR></TABLE>
Adankid
Jan 1, 2009 03:12 PM
b18 hatch mike
Apr 24, 2008 08:32 PM
trianglegreg
Nov 19, 2005 12:54 PM
GTlvr82
25
Apr 4, 2003 03:09 AM
EKB18BPR3
Aug 18, 2002 02:43 PM
