whats the difference between an obd1 gsr block and obd2 gsr block?
Old Jul 11, 2007 | 01:41 PM
zerovandez's Avatar
Default whats the difference between an obd1 gsr block and obd2 gsr block?
can the obd1 be converted to an obd2?
Old Jul 11, 2007 | 02:08 PM
slowcivic2k's Avatar
Default Re: whats the difference between an obd1 gsr block and obd2 gsr block? (zerovandez)
Oil pump housing is the only difference, because the Crankshaft Flux Sensor bolts to the bottom of the oil pump housing, the OBD1 pump did not have this sensor and thus it does not have to hole to mount it. You will also need the reluctor wheel to make that sensor function.
Old Jul 11, 2007 | 02:35 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: whats the difference between an obd1 gsr block and obd2 gsr block? (slowcivic2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">Oil pump housing is the only difference, because the Crankshaft Flux Sensor bolts to the bottom of the oil pump housing, the OBD1 pump did not have this sensor and thus it does not have to hole to mount it. You will also need the reluctor wheel to make that sensor function.</TD></TR></TABLE>
did that conversion to my b16.. street legal
Old Jul 11, 2007 | 05:15 PM
zerovandez's Avatar
whats a relucter wheel?
Old Jul 11, 2007 | 05:28 PM
Default Re: (zerovandez)
A Reluctor Wheel is a toothed wheel that is usually magnetic, but can be made of any metal that is used in conjunction with a pickup coil (a coil that is energized and when the teeth rotate in close proximity to it, deforms the voltage that produces an analog signal to tell a device that it has passed a certain point. Crank sensors can use this method, or a hall effect switch/sensor to determine crank position.
Normally the Reluctor Wheel has an indexing tooth that is of a different spacing from the rest, to set a common pattern (say 31 short teeth and 1 long one, so the PCM can determine when the crank has made a full revolution.)
Here is a picture of one:
http://www.transmissionpartsus...T.jpg
Old Jul 11, 2007 | 07:13 PM
zerovandez's Avatar
u mean the crank pulley gear that holds the timing belt? can you get me a pic of one that I need for my application?
Old Jul 11, 2007 | 07:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerovandez &raquo;</TD></TR><TR><TD CLASS="quote">u mean the crank pulley gear that holds the timing belt? can you get me a pic of one that I need for my application?</TD></TR></TABLE>
Correct
15 13621-P72-A01 PULLEY, TIMING BELT DRIVE 1 2000 INTEGRA GS-R $58.69
http://www.acuraautomotivepart...ormal
This wheel will work on all OBD2 GSR's and Type R's, make sure to use a GSR or Type R oil pump. A B16 one will not interchange because the wheel is on the other side of the pulley, make sure you take note of that.
Old Jul 12, 2007 | 07:00 AM
zerovandez's Avatar
Thanks!
EM1_00Si
Jul 3, 2007 05:52 PM
EM1_00Si
Jun 10, 2007 09:01 AM
blu3g
Aug 9, 2005 04:31 PM
aw1234dude
Dec 15, 2004 06:32 PM
aw1234dude
Dec 7, 2004 12:56 AM
