Little Leak... INSIDE!!
Old Jul 11, 2007 | 01:16 PM
MDM's Avatar
MDM
Default Little Leak... INSIDE!!
i was driving to work with my girl today with the a/c on (since its about 117 here in Phx.) and i made a left turn and i heard a weird noise under the glove box.
Then, a few seconds later water starts dripping out and it got all over my girls foot(it was pretty funny). Then a few miles later another turn and more water.
A few days ago i took out my floor mat and noticed my carpet was wet on it started smelling after a while, i cleaned it but it happend again!!
I dont know if its cause of the a/c i havnt seen that with out the a/c.
Does anybody have an idea or knows of someone that does?
any help appreciated thanks!
Old Jul 11, 2007 | 01:30 PM
MidwestCivic's Avatar
a/c usually is gas, the heater core could be leaking, or somebody ripped the heaters and dash out and half assed it. Check behind the battery in the engine bay to see if that area is sealed. Are you losing coolant? Check for HIV and post pics of under the glove box, facing the rear of the car next time your girl detects water.
Old Jul 11, 2007 | 01:31 PM
crazyguy's Avatar
Default Re: Little Leak... INSIDE!! (MDM)
it is the ac drain ..
i think your ac hose might be clugged...
that happened to me once
Old Jul 11, 2007 | 01:35 PM
MDM's Avatar
MDM
Default Re: Little Leak... INSIDE!! (crazyguy)
yea the a/c is not that cold sumtimes but i thaught it was cause of the lil whole in my condensor but i JB weld it.. ill check bejind the battery...ill also check the a/c drain and hose.. ill take pics of the LEAK!!!! thanks any more suggestions?
Old Jul 11, 2007 | 01:39 PM
slowcivic2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">it is the ac drain ..
that happened to me once</TD></TR></TABLE>
x2, a clogged hose will force it to leak onto the passenger floor board, soaking the carpet on humid days, happens the same way to a lot of different cars.
Old Jul 11, 2007 | 01:41 PM
MDM's Avatar
MDM
Default Re: Little Leak... INSIDE!! (slowcivic2k)
what hose do i need to check??
where is it located?
thanks
Old Jul 11, 2007 | 01:54 PM
MDM's Avatar
MDM
bumpizzle
Old Jul 11, 2007 | 02:01 PM
It is located near the front swaybar on my 2000 civic on the passenger side, it runs up into the car and to the cooling fins, which is where the condensation collects. Its a solid rubber looking hose that has two holes on the side, it should be easy to spot, because youll probably be like... wtf where does that come from?
Old Jul 11, 2007 | 02:05 PM
MDM's Avatar
MDM
lol.. aight ill go home and look and see if its clogged or sumthing.. thanks, is that the only thing that might be the problem??
Old Jul 11, 2007 | 02:18 PM
The tube may have broken inside the dash, they can become brittle over time, removal of the glove box is also an easy way to check the housing for cracks/leaks.
Old Jul 11, 2007 | 02:23 PM
MDM's Avatar
MDM
yea i was thinking of removing it but i didnt want to be late to work but will be romoved when i get a chance!
Old Jul 11, 2007 | 04:06 PM
eg6sirll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">The tube may have broken inside the dash, they can become brittle over time, removal of the glove box is also an easy way to check the housing for cracks/leaks.</TD></TR></TABLE>
x2 and also x2 the hose being clogged. if the heater core was leaking you would smell coolant like crazy. also you said it only happens when you make a turn, if it was the heater core it would leak all the time.
Old Jul 11, 2007 | 08:10 PM
MDM's Avatar
MDM
Default Re: Little Leak... INSIDE!! (eg6sirll)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sirll &raquo;</TD></TR><TR><TD CLASS="quote">
x2 and also x2 the hose being clogged. if the heater core was leaking you would smell coolant like crazy. also you said it only happens when you make a turn, if it was the heater core it would leak all the time. </TD></TR></TABLE>
yea only on turns..
so its the clogged up hose bejind glove box right??
Old Jul 12, 2007 | 01:16 PM
Yes, it is either the hose has a hole, or it is clogged and flooding the climate module and it is seeping out the sides of the holder.
Old Jul 12, 2007 | 01:17 PM
MDM's Avatar
MDM
aliright thanks for the help!!
C4st0r_Tr0y
Honda Civic (2001 - 2005)
Aug 8, 2018 09:20 AM
408bagged
Feb 3, 2011 05:58 PM
DACteg
Jul 27, 2010 11:04 AM
darkestfenix
Jun 24, 2010 09:36 PM
Maness
Jul 31, 2006 01:08 PM
