Water, AC Vents?
Water, AC Vents?
So the other day I was driving around and some times when I would make a turn in either direction water would spit out of my floor vents (I think, I doubt it would just be in the dash) and onto the floor. This was repeatedly happening throughout the day.
I hadn't realized how much water had actually come out, or if more had come out while its been sitting there, but my car smells like wet ******* dog.
Where the hell did this water come from?
Re: Water, AC Vents? (steelrainwarrior)
mines leaking.....ive called 3 different auto part stores....rebuilt ones are ranging from about $370 - 300.....
know anything about a switch in the back of the dash to fix the thermostate?
Re: Water, AC Vents? (Maness)
check the ac drain tube on the fire wall these things get clogged and the water can't run out. So it just fills up the box and spills out when you turn. pop the hood and look for a 1/2 rubber tube comming out of the fire wall heading to the ground. use something thin to unplug the tube
darkestfenix
06-24-2010 09:36 PM
gtowni3
10-05-2004 06:19 PM
