i broke my hydro conversion (innovative)
Old Jul 11, 2007 | 09:52 AM
civiconfire's Avatar
Default i broke my hydro conversion (innovative)
at about 11:30am i went to pick some stuff up down south.. got it was going to make a quick stop at a shop on the way back... before i could get there my shifts were getting harder ... 1:15pm next thing you know the peddle springs to the floor (like when the cable is off)
im like F*#k, S#!t....ect because im not close to home and no way i can pay to get it towed that far.
pop the hood take a look... the S#!t is hanging.. take a better look the point were it pivots it has a bolt and nut.. the bolt is broken and the other half is gone... they should have made the crap a little better.. i only have had it on there for 3 months with a stage 1 exedy . im going to call them to see what i can do about a replacement bolt... or something stronger. that was BS
Old Jul 11, 2007 | 10:25 AM
Super Chicken's Avatar
Default Re: i broke my hydro conversion (civiconfire)
That sucks to hear as I have the same item with my swap
Old Jul 11, 2007 | 10:45 AM
Lamchop0000's Avatar
we want pics! that just sucks
Old Jul 11, 2007 | 10:59 AM
89hatcher's Avatar
yeah post pics...damn that sucks was about to order mines too.
Old Jul 11, 2007 | 11:09 AM
slow96coupe's Avatar
yikes man... im running a twin disk with mine...
is it the one w/ the master cylinder or the pivot one w. no master cylinder...
Old Jul 11, 2007 | 11:24 AM
EL Vap133's Avatar
Pics! Luckily my Hasport conversion has not broken on me and I have had it for about 3-4 years, just after it came out.
Old Jul 11, 2007 | 11:42 AM
burnt_rice's Avatar
damn that sucks man i have a hasport mount kit havent used it yet..havent heard anything bad about them breaking......was gonna use innovatives kit i may still consider to use their master cyl kit cause of records of cable stretching through the use of both the hasport and innovative pivot kits
Old Jul 11, 2007 | 11:45 AM
goforbroke's Avatar
MEAT PATTY
Default Re: (burnt_rice)
Theirs lots of mixed feeling about these hydro kits from Hasport and Innovative. I've seen threads bashing both kits.
Old Jul 11, 2007 | 12:34 PM
dem0nk1d's Avatar
in my eg i had the clutch slave cylinder go out. I made it all the way home, with no probs. you need to know how to shift with out using the clutch. only use when **** happens. I usually pop the stick out of gear then rev the motor up to 4g's and then slip into the next gear i never grind it either... it will fall into place...
like i said this should only be used in the type of case.
Old Jul 11, 2007 | 07:37 PM
Default Re: (dem0nk1d)
its the pivot w/o master cylinder... and i can shift with out using the clutch.. but im not about to chance it with my b16 tranny .
i have a nut and bolt ghetto rigged in there so i can get to work. but i will take a pic of what broke... its a bolt that the whole thing pivots on. not the one with the ball but the other one
mine kinda looks diffrent.. it has a peace that holds the nut in place so it can not get loose...maybe something new?
Old Jul 12, 2007 | 12:33 PM
i bought the baller one... w/ the master cylinder...
didnt think those would hold up.
Old Jul 12, 2007 | 12:56 PM
89efDUSTY's Avatar
Default Re: i broke my hydro conversion (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Pics! Luckily my Hasport conversion has not broken on me and I have had it for about 3-4 years, just after it came out. </TD></TR></TABLE> LOL
OP just take it to a nut/screw place and get some grade 8 or greater bolt with locking washer & nut...probably a better bet then waiting on innovative
Old Jul 12, 2007 | 07:32 PM
tealjdmcrx's Avatar
here is suggestion find a better grade bolt grind down the threads about 1/4 inch 180 degrees from each other after the nut . then find a dye and clean out the bolt and find a drill press a drill and stick a carter pin thru it as a way to prevent another headache
Old Jul 12, 2007 | 11:38 PM
89efDUSTY's Avatar
Default Re: i broke my hydro conversion (tealjdmcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tealjdmcrx &raquo;</TD></TR><TR><TD CLASS="quote">here is suggestion find a better grade bolt grind down the threads about 1/4 inch 180 degrees from each other after the nut . then find a dye and clean out the bolt and find a drill press a drill and stick a carter pin thru it as a way to prevent another headache</TD></TR></TABLE> not to be an *** but aren't they Cotter pins? Because thats what I always thought.
Old Jul 13, 2007 | 06:21 AM
sounds like a good idea... but im going to make both holes bigger so i can use a bigger bolt... there is nowhere for the bolt to back out on mine and the nut has something covering it so it cant turn. i guess innovative changed a few things because the nuts were falling off. that was not my problem... i broke the bolt off.
Old Jul 15, 2007 | 04:29 AM
o VALTER o's Avatar
hope my hasport never does that!
Old Jul 15, 2007 | 05:04 AM
Boosted Chemist's Avatar
Same here, i got it when it first came out, now everyone is trashing it and saying the innovative is better...
Old Jul 15, 2007 | 07:05 AM
EG_H2B's Avatar
Default Re: i broke my hydro conversion (Boosted Chemist)
That one is way different then the one that I have. Call Innovative, I think they changed it.
jesse777
Jun 18, 2015 02:22 PM
doublek
39
Nov 10, 2009 06:20 PM
Tegraracer90
Mar 26, 2007 02:55 PM
VTAC-KAT
11
Nov 2, 2006 03:19 PM
doublek
Apr 16, 2006 06:54 PM
