Do I need a camber kit?
Old Jul 11, 2007 | 04:34 AM
cvclover's Avatar
Default Do I need a camber kit?
My 99 Si is lowered about 2.5 inches, and the tires have wires stickin out. I never adjusted the camber, the inside of the tire is twice as worse as the outside. What kit should I get for the best price? How do I know what setting to put it as? I'm thinking about doing the rear washer trick in the back to save some $$, but know I need a front kit.
Do I need a camber kit, or just an alignment?
Old Jul 11, 2007 | 04:37 AM
JKov240's Avatar
Default Re: Do I need a camber kit? (cvclover)
You need new tires if you have wires sticking out.
Old Jul 11, 2007 | 04:40 AM
uneek360's Avatar
Default Re: Do I need a camber kit? (JKov240)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JKov240 &raquo;</TD></TR><TR><TD CLASS="quote">You need new tires if you have wires sticking out.</TD></TR></TABLE>
x2.
Get new tires and you don't really need a camber kit just make sure you get your toe set to zero. If you insist on a camber kit just install them and have your local alignment shop align them for you.
Old Jul 11, 2007 | 04:47 AM
cvclover's Avatar
Default Re: Do I need a camber kit? (uneek360)
Thats great news... I don't really have the $$ to spend to get a camber kit. I have enough for tires, but I was holding off until I found out what I needed first.
So no need for front or rear camber kits? Just new tires and an alignment?
Old Jul 11, 2007 | 04:51 AM
uneek360's Avatar
make sure you tell them to set the TOE to zero or within spec and you should be str8. As for the rear you can do this washer trick which is really cheap just search on here or on google.
Old Jul 11, 2007 | 05:20 AM
cvclover's Avatar
So an alignment will take care of the front, but not the back? I'll still have to do the washer trick in the rear?
Thanks for the info so far.
Old Jul 11, 2007 | 05:28 AM
JKov240's Avatar
Default Re: (cvclover)
An alignment isn't a necessity (although I went ahead and got front and rear camber kits for my Civic), however, you need to have the TOE adjusted...along with new tires.
But if you're bent on getting a camber kit, I'd recommend the Skunk2 one. I got mine (front and rear) for $315 shipped.
Old Jul 11, 2007 | 05:40 AM
mikeycivic's Avatar
Default Re: (JKov240)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uneek360 &raquo;</TD></TR><TR><TD CLASS="quote">
x2.
Get new tires and you don't really need a camber kit just make sure you get your toe set to zero. </TD></TR></TABLE>
Old Jul 11, 2007 | 05:42 AM
cvclover's Avatar
Default Re: (mikeycivic)
Ok 2 questions left then.
No camber kits needed, do I HAVE to do the rear washer trick?
Can I just go to a shop and have them adjust my front and rear toe to zero with OEM equipment (minus coils/struts)?
Old Jul 11, 2007 | 05:47 AM
mikeycivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cvclover &raquo;</TD></TR><TR><TD CLASS="quote">Ok 2 questions left then.
No camber kits needed, do I HAVE to do the rear washer trick? NO
Can I just go to a shop and have them adjust my front and rear toe to zero with OEM equipment (minus coils/struts)? YES </TD></TR></TABLE>
Old Jul 11, 2007 | 01:05 PM
uneek360's Avatar
Can I just go to a shop and have them adjust my front and rear toe to zero with OEM equipment (minus coils/struts)?</TD></TR></TABLE>
No you don't have too. But if you wanna look into it here's a link :
http://home.earthlink.net/~civ....html
Beeda
Dec 13, 2007 05:28 PM
nhiczx
Jul 10, 2006 12:03 PM
sngpimpin
Jul 3, 2005 11:20 AM
CivicSwapper
Dec 11, 2003 06:53 AM
TeGGY_LS
Nov 26, 2003 11:16 AM
