p30 ecu
Old Jul 10, 2007 | 08:25 PM
cb71983's Avatar
Default p30 ecu
I was wondering if a p30 acu chipped will damage my jdm B16 motor if I install it, b/c I heard from some friends that it will damge my motor if i plug it in. I need to know if it's good or bad.
Old Jul 10, 2007 | 08:32 PM
jimmypol's Avatar
Default Re: p30 ecu (cb71983)
Hi there, you should run this by the 92-2000 forum.
Old Jul 10, 2007 | 09:16 PM
USDMCIVICHATCH's Avatar
Default Re: p30 ecu (jimmypol)
what motor was it chipped for before you got it ? is your motor stock? A p30 is the ecu that ran the 92-95 jdm b16a and also the usdm 94-95 b16a3 del sol from the factory.
Old Jul 12, 2007 | 07:51 AM
cb71983's Avatar
yes it was chipped when I got it was use on a b20 with a b16 head in a hatch. my b16 has a head job,jdm header,cams,cam gears. the ecu has no rev limiter, I use it on my friends soch d16y8 motor and it made power past 7000 rpm all the way to 8500 rpm.
Old Jul 12, 2007 | 10:43 AM
cb71983's Avatar
Default Re: (cb71983)
is a p28 better 4 it
Old Jul 12, 2007 | 11:34 AM
mustang5.slow's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb71983 &raquo;</TD></TR><TR><TD CLASS="quote">is a p28 better 4 it
ding ding ding...yess offourse it is.
Old Jul 12, 2007 | 08:10 PM
Default Re: (mustang5.slow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mustang5.slow &raquo;</TD></TR><TR><TD CLASS="quote">
ding ding ding...yess offourse it is.</TD></TR></TABLE>
not a stock one they are single cam ecu's that only rev to about 7ish. no doubt it has always been the favorite ecu to use but it would need to get chipped with a b16 base map before he could use it.
you said you already tried the p30 on your friends d16 and reved it to 8500 did it hit the rev limiter at 8500? cuz if so then its a stock p30. i say just use it anyway
Old Jul 13, 2007 | 03:18 PM
pArAdOxsqUArE's Avatar
pm'd you...
Old Jul 13, 2007 | 03:42 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: p30 ecu (pArAdOxsqUArE)
Rechip the P30 with a local tuner and you will have better results
hmoobthojboi07
Aug 29, 2008 03:35 AM
Speed_1
Jul 27, 2006 08:17 PM
Jap_Spec_Imports
Apr 25, 2006 04:24 PM
Rionmann
Feb 3, 2006 04:20 PM
turboed4life
May 9, 2004 05:03 PM
