Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Vacuum leak or charcoal canister which is my problem?
Old Jul 10, 2007 | 01:00 PM
Shintakun's Avatar
Default Vacuum leak or charcoal canister which is my problem?
ok. so im having issues with either one of these i dont know but the symptoms seem the same.
my car
01 Honda Civic LX
53,210 miles
Coupe
Standard tranny
i drive then i go to a complete stop my engine turns off. everything else is on. (not abruptly) it turns off you dont even notice until power steering is gone.
im driving on the high way and cruise down hill on neutral, my cars engine turns off, and i notice with power steering gone as well.
it suddenly doesnt happen sometimes and it does happen sometimes i just dont know what causes it. but recently i just put in a new SRI into my car. its Ebay brand tubing with a K&N filter. and the problem arrose again around 25 miles of driving with it. the
O2 sesnsor is fine so i dont know what else could be the issue. is there a way i could diagnose this without dropping an arm and a leg at a mechanic shop?
Old Jul 10, 2007 | 01:06 PM
toyomatt84's Avatar
Sanji
Have you ever replaced your battery?
Old Jul 10, 2007 | 01:07 PM
Shintakun's Avatar
Default Re: (toyomatt84)
yeah i replaced it about 2 months ago
Old Jul 10, 2007 | 01:58 PM
Shintakun's Avatar
Default Re: (Shintakun)
dont flame cuz i bumped >.< this is a problem i would like to deal with without paying a mechanic to fix a probrlem thats less than 50 for 200-400.....
Old Jul 10, 2007 | 02:00 PM
fventura03's Avatar
weird. why do you go into neutral on hills? lols
Old Jul 10, 2007 | 02:50 PM
Shintakun's Avatar
Default Re: (fventura03)
over here in TX the hills are pretty steep. lets say about a 45 angle on average in the lake Side of Austin TX
Old Jul 14, 2007 | 06:32 PM
Shintakun's Avatar
Bumping it. it stopped but it happens sometimes
Old Jul 15, 2007 | 09:11 AM
MatterMatt's Avatar
The charcoal canister and o2 sensor wouldn't have anything to do with your engine shutting off, and if you had vacuum issues you would notice other problems (running rough, poor mpg, etc.). Sounds like a possible ignition switch or other ignition or charging system problem. Sounds like you should take it somewhere.
Old Jul 15, 2007 | 12:58 PM
jivi's Avatar
Default Re: (MatterMatt)
I can help you deal with this problem maybe. Because of your new intake system the ECU has change the AF mixture which give you an erratic idling which lead to stopping your engine. Try to reset the ECU by removing the blue fuse(15A) for 5 minutes and install it back again. Then start the engine with all the accessories off/AC off in idle throtle for 5 minutes, then start driving your car with AC ON at medium speed 20 to 40kph for 2 minutes then at high speed for another 2 minutes. now your ECU has been re-programmed for its proper AF mixture.
BTW: the fuse is located in the under hood fuse box. HTH.
Old Jul 15, 2007 | 02:56 PM
MatterMatt's Avatar
Default Re: (jivi)
No. The AF ratio is not drastically affected by just putting an intake on. No amount or type of driving "re-programs" the ECU for the proper AF mixture.. The ECU uses sensor inputs to change long term and short term fuel trim to create optimal AF ratio (based on O2 sensor readings and AF ratio sensors on newer Hondas). Sure, make sure the intake is installed right, but your problem lies elsewhere.
Old Jul 15, 2007 | 04:53 PM
jivi's Avatar
how about if he's going to try to do it and let's see what will happen, there's no harm on doing that
Old Jul 15, 2007 | 09:36 PM
MatterMatt's Avatar
Default Re: (jivi)
I do not believe you are correct. There is harm in doing that because you are giving the author inaccurate information that is misleading and will keep him from looking into plausible causes for his problem. AF ratio is not reset or reprogrammed, and an intake does not have such a significant impact on fuel trim that it would cause a car to shut off. Ignition switch, ignition, or charging system is the likely problem. Period.
Based on my perception of your skill level I believe you should take it to a professional.
Old Jul 15, 2007 | 11:36 PM
jivi's Avatar
Owowow I'm inaccurate?
It happen to me before and did the ECU reset and it work that's the reason why i'm sharing this info to him.
BTW. not only AF ratio is re-programmed, by doing the ECU reset all sensor attach onto it are in default settings and doing the steps (my first post) given above will teach the ECU to learn the new set-up/settings which in his case the new intake system.
FYI: do you know that even the Auto up-down movement of your window is controlled by ECU?
Maybe my english wasn't good but I'm trying my best to explain it to you.
If i'm wrong i stand to be corrected but if this info will help him solved his problem then i'm happy for him.
Old Jul 15, 2007 | 11:43 PM
EM2ner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MatterMatt &raquo;</TD></TR><TR><TD CLASS="quote">I do not believe you are correct. There is harm in doing that because you are giving the author inaccurate information that is misleading and will keep him from looking into plausible causes for his problem. AF ratio is not reset or reprogrammed, and an intake does not have such a significant impact on fuel trim that it would cause a car to shut off. Ignition switch, ignition, or charging system is the likely problem. Period.
Based on my perception of your skill level I believe you should take it to a professional. </TD></TR></TABLE>
Damn man take it easy.. Jivi was just giving his suggestion. Who know's it might be something stupid like that.. You never know with cars nowadays
Old Jul 15, 2007 | 11:46 PM
jivi's Avatar
Default Re: (EM2ner)
My bad It's ECU parameters which is resetted not Sensors. sorry for that.
EDIT: EM2ner thanks for consideration
Old Jul 15, 2007 | 11:52 PM
EM2ner's Avatar
Default Re: (jivi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jivi &raquo;</TD></TR><TR><TD CLASS="quote">My bad It's ECU parameters which is resetted not Sensors. sorry for that.
EDIT: EM2ner thanks for consideration </TD></TR></TABLE>
No prob pal Wow I'm surprised no one asked If CEL Was on?
formerRac3r
Transmission & Drivetrain
Feb 4, 2019 12:58 PM
captainrich
Honda Fit
17
Aug 1, 2011 02:43 PM
vbkapousidis
Mar 6, 2008 01:00 PM
HondaH22A
Jul 20, 2006 12:36 PM
