Dipstick t00b is loose... :|
Old Jun 8, 2002 | 08:23 AM
Willard's Avatar
Default Dipstick t00b is loose... :|
Anyone else have this issue?
Once my car is warm, the dipstick tube loosens up allowing rotation and even removal.
I have tied the dipstick/t00b down using some wire that is looped under one of the header shield bolts...
Oil + hot stuff = :FIRE:
I know of one other 2001 ITR owner that had this issue...
'JB weld' is how he fixed his...
Thoughts?
Will
Old Jun 8, 2002 | 08:29 AM
EagleR's Avatar
Default Re: Dipstick t00b is loose... :| (zyg)
plenty of loc-tite?
Old Jun 8, 2002 | 08:55 AM
D's Avatar
D
Default Re: Dipstick t00b is loose... :| (Willard)
to JB weld... actually, i prefer JB quick. shrug.... loose toob... heh.
Old Jun 8, 2002 | 09:08 AM
sneakychaos's Avatar
Default Re: Dipstick t00b is loose... :| (D)
Mine has it too, Will. Dunno what the dilly is.. but if you got some suggestions, let me know.
Old Jun 8, 2002 | 09:18 AM
Willard's Avatar
Default Re: Dipstick t00b is loose... :| (trooth)
It seems like the t00b was a interferance fit to begin with... Maybe purchase a new t00b from the dealer and see if it is a tight fit to install.
If not... some JB is by friend.
Will
-who would like to have a new block... but would not trust the dealer to install it.
Old Jun 8, 2002 | 09:23 AM
Back in Black's Avatar
Rather OG
Damn it, Will! J B 0wnz j00!
Jason-
who's t00b is still tight
Old Jun 8, 2002 | 09:30 AM
Bob#455's Avatar
I just noticed yesterday that my dipstick was facing an odd direction, even though I normally keep it straight. Sure enough, when I went to straighten it, the tube was loose, not the dipstick. I didn't try to remove it...but I'm sure it would come out. Does it thread on there or just sort of pop in? Anyone know a good way to fix this, besides JB Weld
Old Jun 8, 2002 | 10:05 AM
yoshi234's Avatar
I shoot brides
fug, l00s t00b
yshay - who'll have to do a l00s t00b check after some lunch w/ da Tall @55 Honkay
Old Jun 8, 2002 | 11:09 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
yeah wtf
too bad I can't hear the tube over my exhaust
Old Jun 8, 2002 | 11:16 AM
ITR764's Avatar
Default Re: Dipstick t00b is loose... :| (Ross)
what about some loctite 680 high temp??? that chit is a retaining compound...
Old Jun 8, 2002 | 11:21 AM
Willard's Avatar
Do any of you leak oil because of this?
The base of teh t00b has leaked since the second track evnet...
Slow leaks are a lot safer than a splash of oil on the header.
Will
Old Jun 8, 2002 | 11:40 AM
yoshi234's Avatar
I shoot brides
dis thread made me go thru my huge bank of pix. whadaya know, my chit <u>is</u> leaking
yshi - who just played it off as accumulation of dirt at da time
Old Jun 8, 2002 | 11:43 AM
Willard's Avatar
Default Re: Dipstick t00b is loose... :| (yoshi234)
My car has leaked since ~5,000 miles...
Old Jun 8, 2002 | 12:33 PM
kenji's Avatar
25 Year Member
It is normal for the dipstick tube to leak a little.
If oil is pouring or spraying out it is not a good thing.
-kenji
Old Jun 8, 2002 | 01:59 PM
TodaSi's Avatar
Yep, all in one spot yo! Makes ya wonder.
Old Jun 8, 2002 | 02:04 PM
Edwin's Avatar
This happened to my car too.
Had the dealer replace the whole oil dipstick cylinder and assembly under warranty.
Old Jun 8, 2002 | 02:10 PM
Bob#455's Avatar
I don't think mine is quite that dirty, but it looks the same way... Oil seeping out from the dip stick tube... What is the deal with this guys? Should it be fixed under warranty or just leave it?
Old Jun 8, 2002 | 02:37 PM
Driver's Avatar
Default Re: Dipstick t00b is loose... :| (Edwin)
same here !
Old Jun 8, 2002 | 04:28 PM
Chayse's Avatar
New User
Had the same thing. Dealer replaced it under warranty. Go there now! The last time I checked the oil, the tube spun around the wrong way after the dipstick was out. Could not twist the tube back and could not inset the dipstick either. went to the dealer the next day and complained.
Old Jun 8, 2002 | 05:14 PM
JDMITR222's Avatar
Default Re: Dipstick t00b is loose... :| (Chayse)
I fixed mine by getting some JB weld,putting it on lightly on the tube's very base.I then used a open ended wrench and tapped on the wrench with a hammer.
As for one of the questions from before. No it is not threaded.its just like the rest of the tube it's round.
Old Jun 8, 2002 | 05:56 PM
JDMAllMota R731's Avatar
Willard: I had the problem also...I was driving for 30 mins and all of sudden my dipstick came loose, splattering oil all over the block...So my buddies and I used JB WELD to solve the problem...But make sure to let it dry for 24 hours...
Old Jun 9, 2002 | 12:25 AM
Austin's Avatar
Default Re: Dipstick t00b is loose... :| (NightHawkBlk R731)
Same problem here...I replaced it...it cost ~$10 no problems after I replacd it.
Old Jun 9, 2002 | 03:37 AM
Ausmith's Avatar
Your what hurts?
Old Jun 9, 2002 | 03:41 AM
Ausmith's Avatar
Default Re: Dipstick t00b is loose... :| (Ausmith)
Seriously...
Z man told me that the stock breathing capacity of the Arrr is not ample for constant high RPM thrashing.... the black gold will find a way out somewhere. In your case the dip stick.
SpeedPak's Avatar
dayum. I typed an entire post about how I wanted to run out and check my dipstick too...then i realized i dont have an ITR anymore
Oh well.
