Dipstick t00b is loose... :|
#27
Re: Dipstick t00b is loose... :| (Austin)
Same problem here...I replaced it...it cost ~$10 no problems after I replacd it.
Will
-who will be removing the header and fixing dis chit in short order...
#29
Re: Dipstick t00b is loose... :| (Ausmith)
Seriously...
Z man told me that the stock breathing capacity of the Arrr is not ample for constant high RPM thrashing.... the black gold will find a way out somewhere. In your case the dip stick.
? What do you mean?
"stock breathing capacity" is not "ample?"
#31
Re: Dipstick t00b is loose... :| (Ross)
what can we do to remedy this problem? Aside from the short-term fixes discussed here?
Once enough oil has leaked.. the t00b becomes loose. At least that is what I think.
I will try to buy a new tube or use some JB weld and seal the leak and hope the t00b stays put.
Will
-who will use this as an excuse to buy a baffled oil pan
#32
Rather OG
Jason-
who knows JB has a purpose
#33
I too have had this problem happen. When the motor is hot, and I got to check the oil, the dipstick and the guider comes out! I will have to swing by Honda to get this fixed, not unless any of you people know how I could fix it. Let me know! Peace.
#34
Re: Dipstick t00b is loose... :| (YellowITR01)
I just applied some Honda-Bond to the dipstick t00b and it is drying... Report tomorrow after a test drive.
Will
-who hopes the H-B works...
Will
#35
Re: Dipstick t00b is loose... :| (George Knighton)
to my knowledge, the tube is just pressure/friction fit. if it's leaking, try using a piece of wood on the top of the tube and pound it back in with a hammer. hth
#36
Re: Dipstick t00b is loose... :| (Willard)
I checked it this morning (~6:15am) and it did not move.
I drove to work and checked it after I parked. It still did not move...
I will wait till after a 'track event' before I say that the repair is a successful one.
If the oil leak has stopped and the t00b does not move... I will be a happy man.
Will
-who wonders why H-B is so expensive....
#37
New User
My dipstick tube was loose as well. I just took it to the dealer and had them replace it. Now it isn't loose anymore. I'd say to just take it to the dealer and let them fix it.
#40
Re: Dipstick t00b is loose... :| (Type-R 940)
A new t00b was only ~$10... but for $12 I could get a t00b of H-B and fix the issue myself and not have to let the dealer touch my car.
Will
#43
Collector-o-Guns and Drinker
Will
Will
Hondabond = liquid duct tape
Pat, who wonders if they have Volvobond...
#44
Re: Dipstick t00b is loose... :| (01-1214)
This happened to my car too.
Had the dealer replace the whole oil dipstick cylinder and assembly under warranty.
same here !
same here !
#45
Re: Dipstick t00b is loose... :| (SoCal ITR)
easy fix here.
https://honda-tech.com/zerothread?id=232850
#48
Re: Dipstick t00b is loose... :| (Bbasso)
Count me in on the list of those with this loose tube issue..
Thanks to Yoshi's reference page and Willard's doggade persistance, I picked up some Honda Bond. Cleaned up everything and reattached the tube.
I'll check it tomorrow.
Hopefully all should be good,
I noticed a slight leak at about 25,000 miles. It now has 30,000 miles and the tube just spun freely.
Thanks guys.
Anton
Thanks guys.
Anton
#50
Re: Dipstick t00b is loose... :| (Big Phat R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R »</TD></TR><TR><TD CLASS="quote">where are all these dead threads coming from?</TD></TR></TABLE>
They Ain't dead if they're useful.
http://www.socalitr.com/HTlinks
Funny how when people ask questions without searching and reading a bit first they get slammed,
Then when other people actually Do some research, other members are bewildered at where and why old threads emerge.
NOTHING against you BPR, I've just seen your same comment a few times before in the last few weeks from other older members.
I personally would rather the New one's do the Search and Find the Information. That's what makes this board so great and unique.
