compression test
Old Jul 9, 2007 | 07:12 PM
jdm.fanatic's Avatar
Default compression test
I just rebuilt my 95 ls integra motor with forged pistons and rods with 8.9 to 1 pistons and came up with messed up results on the comp. test 125 135 155 160 and 150 150 170 200 with a little oil. I checked and rechecked the piston ring gaps to 15 thou. Cant find a leakdown test kit to check that. Any help?
Old Jul 9, 2007 | 11:37 PM
base-op.1320's Avatar
Default Re: compression test (jdm.fanatic)
And you are doing the leakdown test cause? is it running bad or you just built it and wanted to check it before running it?
humboldt_skim
May 31, 2008 08:18 AM
Cheez-It
Oct 2, 2007 07:27 PM
DxTrix
Aug 15, 2003 04:58 PM
Triple T
Feb 10, 2003 03:32 PM
Propulsion
Jun 5, 2002 11:48 PM
