d16z6 swap into 99 ek dx..
i got the swap done just need to know how to wire..what would i have to do..would it be plug and play or do i have to get new wire harness..any help would be appreciated.
its not plug and play because your old y7 was obd2 and your new z6 is obd1
you need the z6 harness on it, but im not sure what modifications you will need to make it work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMCIVICHATCH »</TD></TR><TR><TD CLASS="quote">actually he needs the y7 harness on it, he needs to modify it to fit</TD></TR></TABLE>
yup use your y7 harness.
extend some wires near your intake manifold if need be.
use your y7 dizzy
run your vtec soleniod, and vtec oil preassure switch to ECU and wammo
use your y7 dizzy
by using the y7 harness u guys meant the engine harness right..take out the z6 engine harness and put the y7 harness on..then just wire the vtec soleniod and vtec oil pressure to the ecu then i'm set..correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilo_goki »</TD></TR><TR><TD CLASS="quote">by using the y7 harness u guys meant the engine harness right..take out the z6 engine harness and put the y7 harness on..then just wire the vtec soleniod and vtec oil pressure to the ecu then i'm set..correct.</TD></TR></TABLE>
yup, use your y7 dizzy
when u put a z6 in a 96 and up civic body youll need from a z6
Z6. Distributor, VTEC solenoid, crank pulley, cam gear, timing belt, alternator belt, and timing belt covers and p28 ecu
All of the sensors from the OBD2 harness hook right up to the OBD1 sensors. The TDC sensor is on the crank on a Y8, and in the distributor on a Z6. You need to repin the dist wires to match them correctly to the harness, or you can buy a conversion harness from Rywire.com. There is also no knock sensor on the Z6, so that will be left sitting as well. I slapped my Y8 mani onto the Z6 so I had no issues with the sensors on the IM. OBD2A - OBD1 harness and a chipped P28 spec ECU.
You don't want to use a Y8 crank pulley on the Z6. You will have nightmares.
92-00 trannies/clutch/flywheel are all interchangable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeanGreenMachine »</TD></TR><TR><TD CLASS="quote">when u put a z6 in a 96 and up civic body youll need from a z6
you ll keep your y7 dizzy... do not use the z6 as it will not hook up...
and since you are converting to OBD 1 you wont need knock or crank sensor...
What is this guy doing? just keep yoru z6 stock im not sure why he is listing all those parts (cam, crank, belt...) whatever...
dont listen to him he didnt take his time reading the thread and saw that your car was running already...
such a simple matter turned so complicated...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Lobster »</TD></TR><TR><TD CLASS="quote">
and since you are converting to OBD 1 you wont need knock or crank sensor...</TD></TR></TABLE>
on the obd1 z6 the crank sensor is in the dizzy isnt it, so if your using a y7 harness on the z6, the crank sensor plug in will be left hanging right???? because on the z6 the crank sensor is in the dizzy......where as the d16y motors have a crank sensor in the oil pan or near the crank area....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaPartsHero »</TD></TR><TR><TD CLASS="quote">i didn't think you could pass smog with an older motor than the cars year</TD></TR></TABLE>
we dont smog here
we dont smog here
Yomage_EG
Sep 24, 2013 11:26 AM
capbyrd
Oct 14, 2004 12:34 PM
