H2B - How Much Oil Should Appear On Dipstick?
Old Jul 9, 2007 | 11:03 AM
Coomer's Avatar
Default H2B - How Much Oil Should Appear On Dipstick?
I've got a H2B setup, and I want to ensure that I've got the right amount of oil in the engine. Hopefully we can get some clarification and add this to the H2B FAQ thread.
There is my dipstick. I'm wondering how much oil should appear on the dipstick, since the H22 sits more vertical in a H2B setup.
Old Jul 9, 2007 | 11:53 AM
hpi247's Avatar
Default Re: H2B - How Much Oil Should Appear On Dipstick? (Coomer)
I put 5 quarts into mine, and im up around 2 to 2 1/2 inches.
Old Jul 9, 2007 | 12:15 PM
Coomer's Avatar
Default Re: H2B - How Much Oil Should Appear On Dipstick? (hpi247)
Is that after you drain all of the oil out of it, through a modified/different pan or some sort of a pump to remove all the oil?
Or is that after you simply drain as much oil as possible out of the factory drain plug on the H22 pan?
Old Jul 9, 2007 | 01:18 PM
Bense's Avatar
here's what you do
1. find out how many qts of oil a prelude takes
2. pour that amount of oil into the engine
3. mark the dipstick accordingly.
Old Jul 9, 2007 | 02:42 PM
hpi247's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Coomer &raquo;</TD></TR><TR><TD CLASS="quote">Is that after you drain all of the oil out of it, through a modified/different pan or some sort of a pump to remove all the oil?
Or is that after you simply drain as much oil as possible out of the factory drain plug on the H22 pan?</TD></TR></TABLE>
I was wondering what to do about draining the oil because the pan sits different. I just drained it as best i could, and then added 5 quarts of oil. Maybe i will look for some kind of pump to drawl oil out for the next change.
Old Jul 9, 2007 | 02:47 PM
Coomer's Avatar
Thanks for the insight guys.
Hpi, I'm considering doing the same thing. That, or take the pan off, drill a hole somewhere where the oil will drain better, and have a friend weld on a nut so I can put the oil drain plug there.
Old Jul 9, 2007 | 03:02 PM
hpi247's Avatar
Default Re: (Coomer)
I think i have seen something for an oil plug relocation kit. Would probably work well in front of the car. I dont like the idea of old oitl sitting in the egnine. I like to take car of my baby
Old Jul 9, 2007 | 03:19 PM
Coomer's Avatar
Default Re: (hpi247)
I don't like the idea either. At the minimum, I'm at least going to get a magnetic drain plug.
There's this. It's just a nut that you weld on though.
Old Jul 10, 2007 | 06:05 AM
hpi247's Avatar
Yea im planning on ordering a magnetic drain plug for the oil and the trans. It's just added insurance, couldnt hurt. I wish it would be easier to relocate the drain bolt, since i don't have any welding skills.
Old Jul 10, 2007 | 08:20 AM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hpi247 &raquo;</TD></TR><TR><TD CLASS="quote">Yea im planning on ordering a magnetic drain plug for the oil and the trans. It's just added insurance, couldnt hurt. I wish it would be easier to relocate the drain bolt, since i don't have any welding skills.</TD></TR></TABLE>
Get the nut from the url listed above, drill a hole with a 9/16" drill bit (or 1/2" and wobble it) and take it to any welding shop. It cost me 20 dollars.
Old Jul 10, 2007 | 07:31 PM
Alchemist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Coomer &raquo;</TD></TR><TR><TD CLASS="quote">I've got a H2B setup, and I want to ensure that I've got the right amount of oil in the engine. Hopefully we can get some clarification and add this to the H2B FAQ thread.
There is my dipstick. I'm wondering how much oil should appear on the dipstick, since the H22 sits more vertical in a H2B setup.</TD></TR></TABLE>
I pulled the pan to put a new drain hole on the front of the pan. I used an O2 Sensor bung and plug, which worked out nicely because its easy to weld. Then I refilled with oil, checked the level and drilled a new hole in the dipstick.
Old Jul 11, 2007 | 09:14 AM
RotiEatter's Avatar
Ditto
Coomer, is this your first motor swap? [just curious]
Old Jul 11, 2007 | 09:43 AM
Coomer's Avatar
Default Re: (RotiEatter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter &raquo;</TD></TR><TR><TD CLASS="quote">Coomer, is this your first motor swap? [just curious]</TD></TR></TABLE>
In a Honda, yes. This was my first motor swap.
Old Jul 11, 2007 | 04:10 PM
dannis.'s Avatar
Thats a sexy Celica... but i would have opt for the gt four spoiler. just curious do you still happen to have it?
Old Jul 12, 2007 | 12:14 AM
Coomer's Avatar
Nope. I sold it. And the GT-Four spoiler only fits hatchbacks.
Old Jul 14, 2007 | 04:18 PM
jakeiscool's Avatar
Banned
5.2 quarts.
Safety_Driver
10
Jan 16, 2012 12:45 PM
EGgoJDM
Dec 1, 2009 12:05 PM
pjr710
Jun 3, 2008 03:45 AM
D16y8_619
Sep 8, 2006 09:05 PM
IVANITR
Nov 30, 2001 01:05 AM
