Random Check Engine Light
Old Jul 9, 2007 | 08:46 AM
96 EX's Avatar
Default Random Check Engine Light
alright i own a 96 ex with a d16y8 nothing special 7.5 fidanza flywheel stage 2 centerforce clutch drop in k&n air filter an a fart muffler with a unorthodox crank pulley. As of right now the check engine light is off but randomly it will kick on and miss fire throughout the cylinders and then throw a code that the computer was fixing it or some dumb bullshit. any ideas?
Old Jul 9, 2007 | 08:55 AM
96 EX's Avatar
Default Re: Random Check Engine Light (96 EX)
bump anyone?
Old Jul 9, 2007 | 09:07 AM
civic1234's Avatar
check plugs, wires, distributor, even injectors... CEL usually comes on when a problem persist... like a miss fire will throw a code when it happends 40 times in a row... I had this problem with my truck it was actually an injector causing a misfire. (but thats chevy for yah)
Old Jul 9, 2007 | 09:23 AM
Dool_Ohver_Hed_Cam's Avatar
sounds like a bad O2 sensor. Wait until it does it again and then see what code it's throwing. O2 sensors aren't cheap, so you want to make sure that it isn't something else.
Old Jul 9, 2007 | 07:28 PM
96 EX's Avatar
Default Re: Random Check Engine Light (Dool_Ohver_Hed_Cam)
it was throwing a o2 sensor code but i got a new one and it quit so now its just randomly doing it and ive gotten new wires plugs distributor cap and rotor button so i dont know lol
Old Jul 9, 2007 | 08:02 PM
97Ej6mike's Avatar
Are you sure its the right one, in OBD2 there are 2 o2 sensors, primary and secondary.
Old Sep 4, 2012 | 12:27 PM
willpost88's Avatar
im having the same problems with my four door ek
Old Sep 4, 2012 | 03:51 PM
lxdriver's Avatar
Yup same here and I got a code of P0420
Old Sep 4, 2012 | 03:57 PM
Motionek55's Avatar
Check simples bro. Mileage of vehicle? miles on spark plugs? and wires?
Old Sep 4, 2012 | 04:00 PM
Motionek55's Avatar
02 sensors simply tell you whats going on inside your engine by reading exhaust gases, temp and etc....check the simples if your getting a misfire code check your plugs and wires, fuel and injectors and then if all else fails check ur 02.
dgdarien
Jul 21, 2015 05:55 PM
jayrod7
Jan 21, 2010 01:45 PM
Mad Money
Sep 27, 2006 08:22 AM
civic_boi
Mar 28, 2004 03:06 PM
