Transmission slime problem~
Old Jul 8, 2007 | 08:08 PM
archerhoyt's Avatar
Default Transmission slime problem~
Here is what the inside of my transmission looked like when i removed it and all the brown scrapped out in a curly gritty slime. Im not sure if it was brake fluid or what but I do konw that it should only be dusty, not slimy so if anyone can give me advice on waht the cause of this was and what i need to do before i re install I would GREATLY appreciate it.
~Lucas
Old Jul 8, 2007 | 09:06 PM
dude_123's Avatar
Default Re: Transmission slime problem~ (archerhoyt)
Was the transmission dust plate on?
Old Jul 8, 2007 | 09:15 PM
WillieWillieFast's Avatar
Check the main seal on the block and see if it's leaking.
Old Jul 9, 2007 | 09:19 AM
Mista Bone's Avatar
D Tranny Guru
Clutch dust + brake fluid + engine oil = nasty mess.
It is also wet, feash leakage.
Old Jul 9, 2007 | 01:08 PM
archerhoyt's Avatar
This "main seal"... is it the only seal that could fail and result in this way?
Old Jul 9, 2007 | 09:42 PM
Mista Bone's Avatar
D Tranny Guru
three seals that can cause that......
main seal on rear of the crank
main seal on the input shaft
seal on the slave cylinder
Take a pic of the block after removing the flywheel.
Old Jul 10, 2007 | 11:54 AM
-DC2-'s Avatar
it's the slave cylinder i bet
mine looked the same
chansta
Nov 3, 2010 07:11 PM
blasterman87
May 14, 2010 01:41 PM
TigerLy
Dec 24, 2008 01:04 PM
CivHizzle
Nov 22, 2004 07:18 PM
nijia555
Jan 10, 2003 12:07 PM
