D16Y7 Coolant Hose Routing
Old Jul 8, 2007 | 01:55 PM
81CB900C's Avatar
Default D16Y7 Coolant Hose Routing & Turbo Vacuum Lines
Where does the hose from the pipe on the back of the block go?
In fact, where do all of them go just to be sure we have them all correct?
Got the one under the dizzy to the core switch, switch to firewall, firewall back to stat housing, the little one from the stat housing to the throttle body, upper & lower of course... I can't think of any others.
Also, when connecting the turbo vacuum lines - the outlet on the compressor-side goes to the side of the waste-gate, the top vents into the atmosphere, and the BOV goes to manifold vac, yes?
-RJ
Modified by 81CB900C at 3:41 PM 7/8/2007
Modified by 81CB900C at 3:42 PM 7/8/2007
Old Jul 8, 2007 | 02:42 PM
81CB900C's Avatar
Default Re: D16Y7 Coolant Hose Routing & Turbo Vacuum Lines (81CB900C)
bumpid
Old Jul 8, 2007 | 03:36 PM
1992Si's Avatar
The hose from the nipple on hte water transfer tube goes to the IAC on the back of the intake.
And yes to the other question.
I guess you figured out where the bypass hose goes.
Old Jul 8, 2007 | 04:40 PM
81CB900C's Avatar
Default Re: (1992Si)
but there's already a hose from the throttle body to the IAC that hasn't been changed.
Old Jul 8, 2007 | 06:53 PM
81CB900C's Avatar
Default Re: (81CB900C)
So anyone have a diagram?
Old Jul 8, 2007 | 09:20 PM
81CB900C's Avatar
bump
Old Jul 11, 2007 | 03:45 PM
81CB900C's Avatar
.... bump?
it's the line from the coolant tube on the back of the block. Where does it go???
Old Jul 11, 2007 | 03:55 PM
EL Vap133's Avatar
Old Jul 11, 2007 | 03:59 PM
81CB900C's Avatar
Default Re: D16Y7 Coolant Hose Routing & Turbo Vacuum Lines (EL Vap133)
... awesome.
We need to make sexi time and have lots of babies...
but seriously - it looks like it's saying the line goes from the tube to the intake nipple? because there's nothing there to hook up to. And that intake is a little different. I could take pics if it'd help?
Old Jul 11, 2007 | 04:12 PM
EL Vap133's Avatar
Pics would help. What year D16Y7 do you have? Do you have the stock intake manifold on it?
Old Jul 11, 2007 | 04:18 PM
81CB900C's Avatar
liiiik 96 or 98? and yes.
Old Jul 11, 2007 | 04:19 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 81CB900C &raquo;</TD></TR><TR><TD CLASS="quote">liiiik 96 or 98? and yes.</TD></TR></TABLE>
Yes, sometimes they might change a few minor things or two.
MurtazaDSM
Nov 27, 2023 05:22 PM
lolv8s
Sep 18, 2017 01:06 PM
jtac616
Oct 10, 2012 04:25 AM
I B BANGGIN
Aug 12, 2007 04:32 PM
2000vsm
Aug 25, 2003 07:14 PM
