D16y8 OBd2 wiring help
Old Jul 6, 2007 | 08:46 PM
stivic's Avatar
Default D16y8 OBd2 wiring help
Just have 2 questions about the OBd2A engine harness this is the first time I've messed with OBd2 and not sure about these.
I have an extra wire, 1 wire for I think goes to the knock sensor but in reading it says only auto harnesses have them for sohc's is this true. I know my block doesn't have the knock sensor
I don't have a connector on my harness for this plug... Does anyone know what this is.
Modified by stivic at 11:16 AM 7/7/2007
Old Jul 7, 2007 | 05:02 AM
stivic's Avatar
Default Re: D16y8 OBd2 wiring help (stivic)
anyone have ideas
Old Jul 7, 2007 | 07:19 AM
stivic's Avatar
Found 1 more prob with the evap valve. have 2 plugs for it one is a shut off I think. but theres only one spot on the canister... hm.
Old Jul 7, 2007 | 10:00 AM
Slopoke's Avatar
That black sensor on the back of the manifold is the EVAP purge cut solenoid.
And both auto and manual d16y8 use knock sensors.
Old Jul 7, 2007 | 06:13 PM
stivic's Avatar
Default Re: D16y8 OBd2 wiring help (Slopoke)
oh ok thanks... So I need a knock sensor then theres just a hole where it goes. Also does anyone know if the rear tranny L or T bracket whatever its called are the same on EG and EKs or are they a different size. I have an EG one on there now it bolted up to the back of the tranny fine but I have 2 of 3 mounts bolted in and the engine looks tilted. The drivers side mount is about 1-2 inches off from bolting up.
Old Jul 7, 2007 | 06:27 PM
teamworxek9's Avatar
what slopke said. what are you doing to the car if i may ask?
Old Jul 7, 2007 | 06:32 PM
stivic's Avatar
Default Re: (teamworxek9)
Bought a 98 coupe shell... picked up this sohc y8 just to throw in and sell as a running car. I've never owned an EK before and have only delt with OBD1 EGs so some things about obd2 I'm still trying to figure out.
Old Jul 7, 2007 | 07:08 PM
stivic's Avatar
Default Re: (stivic)
So as of right now just need to know if the EG sohc rear t bracket is useable and if a B series shift linkage will work at all
DnellM
Aug 5, 2013 04:39 PM
handa
Aug 29, 2010 04:47 PM
jr000
Aug 30, 2007 09:50 AM
slowerTHANmollasses
11
Aug 13, 2006 09:40 PM
d16rice
Apr 29, 2005 07:10 AM
