D16y8 OBd2 wiring help
Just have 2 questions about the OBd2A engine harness this is the first time I've messed with OBd2 and not sure about these.
I have an extra wire, 1 wire for I think goes to the knock sensor but in reading it says only auto harnesses have them for sohc's is this true. I know my block doesn't have the knock sensor
I don't have a connector on my harness for this plug... Does anyone know what this is.
Modified by stivic at 11:16 AM 7/7/2007
Re: D16y8 OBd2 wiring help (stivic)
Found 1 more prob with the evap valve. have 2 plugs for it one is a shut off I think. but theres only one spot on the canister... hm.
That black sensor on the back of the manifold is the EVAP purge cut solenoid.
And both auto and manual d16y8 use knock sensors.
Re: D16y8 OBd2 wiring help (Slopoke)
oh ok thanks... So I need a knock sensor then theres just a hole where it goes. Also does anyone know if the rear tranny L or T bracket whatever its called are the same on EG and EKs or are they a different size. I have an EG one on there now it bolted up to the back of the tranny fine but I have 2 of 3 mounts bolted in and the engine looks tilted. The drivers side mount is about 1-2 inches off from bolting up.
Re: (teamworxek9)
Bought a 98 coupe shell... picked up this sohc y8 just to throw in and sell as a running car. I've never owned an EK before and have only delt with OBD1 EGs so some things about obd2 I'm still trying to figure out.
Re: (stivic)
So as of right now just need to know if the EG sohc rear t bracket is useable and if a B series shift linkage will work at all
slowerTHANmollasses
11
08-13-2006 09:40 PM
