Tranny qustions
Old Jul 5, 2007 | 10:36 PM
Sicky_99's Avatar
Default Tranny qustions
I have a questions about type r tranny I did searches and I didn’t find any similer problems.
I have a 99 gs-r with a jdm type r 96 spec engine and tranny swap. The problem is the shifter has a lot of play while in gear, in first I can move it all the way over to fifth and all the gates are really far apart(is this normal?). Prior to the swap the gs-r shifter was tight and close and the linkage was re-used from the gs-r. thank you for any help!
Modified by Sicky_99 at 11:08 AM 7/7/2007
Old Jul 7, 2007 | 10:14 AM
Sicky_99's Avatar
Default Re: Tranny qustions (Sicky_99)
Edited I found one answer. I don't know anyone with a type r to find out if this excessive play is normal. so please anyone with itr reply and lmk I don't want to lose my lsd and put the gs-r tranny back in. thanks.
Old Jul 7, 2007 | 11:32 AM
vxhatched's Avatar
Hey, I have a 2000 Type-R and the shifter and shift point is all the same as any other honda. Preludes and RSX's and New Civic Si's are the only shifters that feel different cause they are cable, but not that much different. All B series tranny in Hydraulic cable are the same Except for gearing and Lsd and so on so forth.
Old Jul 7, 2007 | 11:33 AM
vxhatched's Avatar
Double check your work, check for any loose connections. Good luck its probably something easy. The shifter from the factory should have some play thats normal.
Old Jul 7, 2007 | 01:21 PM
Circuit Star-29's Avatar
Default Re: (vxhatched)
To the OP:
What condition are the bushings surrounding the shift-linkage in? Is everything torqued to spec?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vxhatched &raquo;</TD></TR><TR><TD CLASS="quote">Hey, I have a 2000 Type-R and the shifter and shift point is all the same as any other honda. </TD></TR></TABLE>
I do believe the R shifter has a slightly shorter throw. Ill confirm later...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vxhatched &raquo;</TD></TR><TR><TD CLASS="quote">All B series tranny in Hydraulic cable are the same Except for gearing and Lsd and so on so forth.</TD></TR></TABLE>
USDM B16 = ITR in gearing... GSR is the next in line followed by the LS tranny.
S1/J1 JDM B16A X-Si
3.230
2.105
1.458
1.107
0.848
3.000
4.400
Y1; Y1 w/LSD JDM B16A SiR I
3.166
2.052
1.416
1.103
0.870
3.000
4.266
S4C/Y21 USDM B16A2, B16A3; JDM SiR2, JDM SiR2 w/LSD
3.230
2.105
1.458
1.107
0.848
3.000
4.400
Y80/S80 JDM B16B w/LSD; JDM B18C 96-spec R w/LSD
3.230
2.105
1.458
1.107
0.848
3.000
4.400
YS1 USDM B17A1; JDM B16A X-Si w/LSD
3.307
2.105
1.458
1.107
0.848
3.000
4.400
S1/YS1/A1 USDM B18A
3.166
1.857
1.259
0.935
0.742
3.000
4.400
Y80/S80 B18B
3.230
1.900
1.269
0.966
0.714
3.000
4.266
?? B18B (auto)
2.722
1.468
0.975
0.638 ----
1.954
4.357
S80/Y80; S80 w/LSD, Y80 w/LSD JDM B18C SiR-G
3.230
1.900
1.360
1.034
0.787
3.000
4.400
S80 w/LSD JDM B18C Spec-R
3.230
2.105
1.458
1.034
0.787
3.000
4.785
Y80 USDM B18C1
3.230
1.900
1.360
1.034
0.787
3.000
4.400
S80 w/LSD USDM B18C5
3.230
2.105
1.458
1..848
3.000
4.400
S80 w/LSD EDM B18C Spec-R
3.230
2.105
1.458
1.034
0.787
3.000
4.785
Info taken from HondaSwap.com
Old Jul 7, 2007 | 02:36 PM
rjgerolaga's Avatar
easy. check work. recheck work. tripple check work. used same principle on all worked i've done and always correct what went wrong or missed. it could be a worn bushing or it could be a bent linkage. you wont know till you work and check, double check, tripple check your work. stop getting lazy and start working.
Old Jul 7, 2007 | 05:00 PM
Sicky_99's Avatar
Default Re: Tranny qustions (rjgerolaga)
Ok I have checked to see if any of the likage is messed up but maybe i did miss somthing. for sure i'll check it again know that i know it's not supposed to be like that. thanks for your help guys.
Old Jul 7, 2007 | 05:13 PM
JjuuN R's Avatar
CS kickin' down some good info today.
Old Jul 8, 2007 | 03:31 PM
vxhatched's Avatar
yeah your right the R is slightly shorter.
Old Jul 8, 2007 | 07:40 PM
Black R's Avatar
25 Year Member
check your shift linkage at the stabilizer. if it has come undone it will exhibit symptoms as you describe.....
if that's not it, then it's time to break open the tranny. it's possible missing one of the detente ***** or the selector forks are worn/ bent.
-hth
Old Jul 8, 2007 | 09:08 PM
Sicky_99's Avatar
Default Re: (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">check your shift linkage at the stabilizer. if it has come undone it will exhibit symptoms as you describe.....
I got the swap from hmotors so i don't think it would be in the tranny(I hope!) I havn't had a chance yet to look and see.
EBEATS
Mar 27, 2009 10:22 AM
davidluko
Mar 9, 2007 03:59 AM
LSvtec03
Apr 19, 2004 06:52 AM
StrangerWitCandy
May 31, 2003 06:38 PM
StrangerWitCandy
May 28, 2003 02:14 PM
