98 jdm b20 on a obd2 LS Harness
Old Jul 5, 2007 | 10:34 PM
Japostol78's Avatar
Default 98 jdm b20 on a obd2 LS Harness
whats up folks.....
so heres my deal....dropped in a 98 jdm b20 in my integra...Check Engine Light is on cuz my knock sensor is not plugged in...its not plugged in since the jdm b20 doesnt have one...
So...is there a way i can get rid of the CEL by connecting my knock sensor somewhere else?? or...should i just get the obd2 to obd1 harness and a p75 obd1 ecu??
whats the easiest thing to do???
Old Jul 12, 2007 | 07:00 PM
GS-R Del Sol's Avatar
Default Re: 98 jdm b20 on a obd2 LS Harness (Japostol78)
Check where it's located when people do ls/vtec. Make a hole in the block and stick it in there. You can use one of the alternator bracket holes
Old Jul 12, 2007 | 10:20 PM
Japostol78's Avatar
Default Re: 98 jdm b20 on a obd2 LS Harness (GS-R Del Sol)
thanks for the reply....so you're saying all i got to do is take the connector from my LS block and connect it to the alternator hole on the jdm block?? i'm cool off makin a hole in the jdm block...might mess it up...
Old Jul 13, 2007 | 08:08 AM
Japostol78's Avatar
heres another thing...i think i have to get another knock sensor....lookin at my LS block...looks like the knock sensor is hidden behind the main pulley...i see the wire stickin out from it...correct me if i'm wrong though...
Old Jul 15, 2007 | 06:57 PM
I think you are talking about crank sensor, ls engines didn't come with one, newer once might of, not sure, you have to buy a knock sensor and tap the hole on the alternator bracket and hook up the conector to it, let me know if you still need help, i'll let you know where to find some pics
Old Jul 15, 2007 | 07:48 PM
Japostol78's Avatar
whats up...i stand corrected then...thats the only plug not connected to anything...would the knock sensor still work then? or what else can i do...the LS i got is a obd2...from the 2001 model integra...not sure it makes a difference...but yeah...thats the only thing not connected...
Old Jul 15, 2007 | 07:52 PM
What year is the car, give me all the ingo at once, year of the car, engine, what kind of ecu and any other info that you know, thanks
Old Jul 15, 2007 | 08:18 PM
Japostol78's Avatar
the integra i got is a 2001 LS....b18b1 motor...it says p75-4 on the head...the ecu is a p72...hope this helps...
Old Jul 17, 2007 | 08:56 PM
Japostol78's Avatar
whats up...i might have solved this problem...on the attarco motor page..it says that the jdm engine doesnt use a crank angle sensor...so they say i have to swap out the oil pump with crank sensor...am i right?? if so...how you swap the oil pump..never did that before....heres the link to the page talkin abou swappin the pump....http://www.attarco.com/index.php?mai...products_id=45
Old Jul 21, 2007 | 06:36 PM
You have to drain the oil, take the header off, take off the oil pan off, take valve cover off, timing belt cover, turn the engine 'till the timing lines match up, take off you timing belt, than there should be 4-5 bolts that hold the oil pump, few 10 mm and 2 on the bottom are 12 mm, clean the surface and put some gasket maker on there and go in reverse order how you took everything off, it shouldn't be too hard.
Old Jul 22, 2007 | 06:05 AM
Japostol78's Avatar
cool...thanks for the help GS-R Del Sol..
staz0loaf
Jul 29, 2013 07:40 PM
b20vintegra98
Sep 26, 2011 05:43 PM
B20Panda
Feb 2, 2010 04:29 AM
mini-cRx
Northeast (Sales)
Feb 20, 2009 07:01 AM
gsr336
Jan 25, 2009 04:11 PM
