No fuel, no spark, no cel
The closest I found in my search was this https://honda-tech.com/zero...age=3 but no solution.
Specs 93 del sol, car was put in storage for around 6 months, ran fine before then.
Engine 96 gsr stock, ecu stock gsr, only aftermarket electronics is the viper alarm, also has a quick disconnect steering wheel.
Good as of now:
Engine cranks (very strong no problem)
No check engine light
Car has fresh gas
New battery
Main relay works (tested on another car)
Ecu works (tested on another car)
All grounds have been cleaned up and are all intact (thermo,trans,vc)
New fuel filter
fresh oil
ALL fuses are new, none were blown when I replaced them
All harness plugs seem secure, and clean
Bad:
No check engine light (I wish it would flash to tell me whats wrong)
Fuel pump does NOT prime, but main relay and ecu is good
old coolant, but looks fine
No spark
No money
Please if you think of anything lmk right now I'm double checking every wire near the ecu and engine bay even though nothing has changed the past few months.
The only thing I can come up with is that I got some creature in the car somewhere and it ate some wires
Or something ign related?
I dont have anyone that'll let me borrow their fuel pump or distributor, and I don't want to buy parts until I get some insight from h-t.
Am I missing something or could it be that the fuel pump and distibutor is bad?
Good as of now:
Car has fresh gas
New battery
New fuel filter
fresh oil
Bad:
No spark
No money
92awd4u
Sep 27, 2004 09:23 PM
