max psi on a 9 pound spring
BUT on a 7 pound spring wont the spring start to lose boost at like 25 psi...meaning the spring will let the gate open and not hold it close beacuse it's a 7 pound spring or is my theory wrong ?
generally the rule of thumb is that you can boost around twice the amount of the spring if you use a boost controller. Anything more than that, and sometimes even that can cause spiking issues and unstable boost pressures.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecallmotor »</TD></TR><TR><TD CLASS="quote">I run a 4.3 psi spring and hold about 23-25psi. It will spike to around 30psi and fall back.</TD></TR></TABLE>
What wastegate/boost control setup? Why such a small spring, for low boost in lower gears?
with a 9psi spring my car will make 35psi using manifold pressure to the top of the gates or 40psi (turbo maxed out) with c02 to the top of the gates
I have a .7bar spring in a V44 tial and couldn't build more then 24psi and it started to fall off using a greddy profec a-spec to 21 at redline. I'm going to stack a small .3 bar spring in there and hopefully will be able to hold 25psi until 9-10k. I guess i could be having other problems but I doubt it is my gt3076r maxing out.
The rule of thumb is more like 3x the amt of the spring not 2x. If you are using C02 then Id say you could go like 5 or 6x the spring depending on what pressure you are running at the tank.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke »</TD></TR><TR><TD CLASS="quote">The rule of thumb is more like 3x the amt of the spring not 2x. If you are using C02 then Id say you could go like 5 or 6x the spring depending on what pressure you are running at the tank. </TD></TR></TABLE>
it's 2x for any normal street app
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LeGeND4LiFe »</TD></TR><TR><TD CLASS="quote">
What wastegate/boost control setup? Why such a small spring, for low boost in lower gears?</TD></TR></TABLE>I run drag radails and anymore boost and it blows the tires off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TiAL »</TD></TR><TR><TD CLASS="quote">
it's 2x for any normal street app</TD></TR></TABLE>
Except I can run 3x no problem, in fact I don't every remember seeing a setup I could not boost 3x more then the spring (on springs under 14psi).
9deuce9rr
Mar 28, 2004 12:32 PM
M.K.C.
Jan 30, 2004 10:57 AM
zojirushi
Jan 23, 2002 04:42 PM
