2 step (searched)
A lot of it will depend on your setup, some people can grab traction at a higher rpm range then others. No sense to put it like at 8 grand if you can't gain traction, know what I mean ?
yea i see what you mean but i was trying to get a consensus to see what a good starting point would be for test and tune
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow »</TD></TR><TR><TD CLASS="quote">I set it at 9500 rpm and I build 42 psi on a GT42R
On a stock B16 BTW....</TD></TR></TABLE>
ha
ha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 »</TD></TR><TR><TD CLASS="quote">1000 rpms here and antilag is set to build 47psi at the line.
</TD></TR></TABLE> hey what do you know another idiot
hey guys thanks for the info
What they are saying is it is not a question with a real answer. Different setups are going to be different. Also every engine is different as well. Try different settings and after a few tries you should be able to dial it in.
Also, your question is quite difficult to understand. Try re-wording it so that people can more easily understand what you are trying to ask them.
If I remember correctly you need to set your fuel cut, ign cut and retard rev. Then again I have an aem unit and have never tried it on another ems/piggy back system.
Remember what RCautoworks said as well. If your suspension/tires can't handle dropping the clutch @ 5-6k rpm then why even try?? GL.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scuffywin »</TD></TR><TR><TD CLASS="quote"> hey what do you know another idiot
hey guys thanks for the info</TD></TR></TABLE>
its tuff luv on HT, but they mean well.
hey guys thanks for the info</TD></TR></TABLE>its tuff luv on HT, but they mean well.
t3t67ho, 84mm b16, msd 2 step.
8200 building 8-10 psi depending on the air for the day.
anything less it fell on its face. no anti lag. i am trying to leave at 5-5500 this year. if i get my car done. he hee.
