anyone good with the emanage?
i hooked up my emanage with a boomslang harness..and when i hook it to my laptop it says the dwell switches are set wrong..how should they be set for a 93 prelude h23...and also when i have my emanage hooked up then my car will crank and crank and crank but it wont fire..then i take the emanage off and hook my ecu up with no emanage it will start right up..anyone?
I've got a smartass answer:
Is the Emanage really good for anyone?
But, to properly answer your question, read the following:
http://www.greddy.com/img/PHP/products/pdf/681.pdf
Good luck, and if all else fails, sell the emanglage.
dwell switches are the rotary ***** inside the emanage you take off the end cover and the first tree ***** are supposed to be set according to type of ecu.should be the same settings as the h22
lsvtec101
Mar 18, 2003 11:19 AM
