anyone good with the emanage?
i hooked up my emanage with a boomslang harness..and when i hook it to my laptop it says the dwell switches are set wrong..how should they be set for a 93 prelude h23...and also when i have my emanage hooked up then my car will crank and crank and crank but it wont fire..then i take the emanage off and hook my ecu up with no emanage it will start right up..anyone?
Re: anyone good with the emanage? (ericstambaugh07)
it will probably start but not run!
Re: anyone good with the emanage? (jorge59la)
anyone?
I've got a smartass answer:
Is the Emanage really good for anyone? https://honda-tech.com/forums/images...es/emsmile.gif But, to properly answer your question, read the following: http://www.greddy.com/img/PHP/products/pdf/681.pdf Good luck, and if all else fails, sell the emanglage. |
Re: anyone good with the emanage? (locash)
ya ive got the instructions and it showes how to set them for a h22 vtec but no h23..
dwell switches are the rotary knobs inside the emanage you take off the end cover and the first tree knobs are supposed to be set according to type of ecu.should be the same settings as the h22
