anyone good with the emanage?
Old Jul 3, 2007 | 08:02 PM
ericstambaugh07's Avatar
Default anyone good with the emanage?
i hooked up my emanage with a boomslang harness..and when i hook it to my laptop it says the dwell switches are set wrong..how should they be set for a 93 prelude h23...and also when i have my emanage hooked up then my car will crank and crank and crank but it wont fire..then i take the emanage off and hook my ecu up with no emanage it will start right up..anyone?
Old Jul 3, 2007 | 08:25 PM
jorge59la's Avatar
Default Re: anyone good with the emanage? (ericstambaugh07)
it will probably start but not run!
Old Jul 3, 2007 | 08:35 PM
Default Re: anyone good with the emanage? (jorge59la)
anyone?
Old Jul 3, 2007 | 10:37 PM
locash's Avatar
I've got a smartass answer:
Is the Emanage really good for anyone?
But, to properly answer your question, read the following:
http://www.greddy.com/img/PHP/products/pdf/681.pdf
Good luck, and if all else fails, sell the emanglage.
Old Jul 4, 2007 | 03:46 AM
Default Re: anyone good with the emanage? (locash)
ya ive got the instructions and it showes how to set them for a h22 vtec but no h23..
Old Jul 4, 2007 | 05:09 AM
turboeg77's Avatar
dwell switches are the rotary ***** inside the emanage you take off the end cover and the first tree ***** are supposed to be set according to type of ecu.should be the same settings as the h22
balbowskie
Jan 30, 2013 02:12 PM
elemntsk8r16
Jan 15, 2012 10:02 PM
urmomluvsme
12
May 16, 2005 05:25 PM
LudeyKrus
Jul 8, 2003 09:48 AM
