b16 t3/t4 what kind of oil?
Old Jul 3, 2007 | 05:18 PM
ev13lf's Avatar
Default b16 t3/t4 what kind of oil?
i'm sure this has been covered before, but i'm putting a t3/t4 on my b16. i was running royal purple 530, thinking of just running conventional 530. think this should be a decent choice?
should i go a higher viscosity, or will 530 do the job?
Old Jul 3, 2007 | 05:45 PM
markaria's Avatar
Default Re: b16 t3/t4 what kind of oil? (ev13lf)
i think 5w30 is too thin for a boosted application. I suggest 10w30 as a good all around oil.
Old Jul 3, 2007 | 06:26 PM
non-VTEC's Avatar
Default Re: b16 t3/t4 what kind of oil? (markaria)
5w30 and 10w30 are the same viscosity when hot.
5w30 and 10w30 should work fine if the engine is pretty much stock with the stock bearing clearences.
you could step up to a 5w40 or 10w40 for some added oil pressure since the engine oil will get hotter than normal with a glowing hot turbo in the system. slighly thicker oil wont hurt anything.
Old Jul 3, 2007 | 06:35 PM
quicksilver1689's Avatar
i ♥ snails
yeah 10w40 is what i would personally run just because its going to see a little more heat and peace of mind.
Old Jul 3, 2007 | 10:15 PM
ev13lf's Avatar
Default Re: (quicksilver1689)
thanks for the input guys.
this is my first venture into forced induction, hopefully it'll go smoothly
Old Jul 3, 2007 | 11:01 PM
A.E Motoring's Avatar
Default Re: (ev13lf)
i used 20/50, **** was great, gave me more oil pressure and didnt thin out as quick on hot days
Old Jul 4, 2007 | 01:31 AM
BlackBeastEK's Avatar
Castrol GTX 5w30 all the way!!!!!
Old Jul 4, 2007 | 06:20 AM
Schister66's Avatar
Man U FTW
i used Royal Purple 5w30 and it was too thin...it would pass the compressor side seal on hard boost for some reason...switched to 10w30 and i havent had a problem since
Old Jul 4, 2007 | 12:19 PM
ragethemachine86's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">5w30 and 10w30 are the same viscosity when hot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">i used Royal Purple 5w30 and it was too thin...switched to 10w30 and i havent had a problem since </TD></TR></TABLE>
lol this is why HT amuses me.
Old Jul 4, 2007 | 03:33 PM
Schister66's Avatar
Man U FTW
Default Re: (ragethemachine86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragethemachine86 &raquo;</TD></TR><TR><TD CLASS="quote">
lol this is why HT amuses me.</TD></TR></TABLE>
I'm glad that amuses you, but the fact remains...i changed to a 10w30 and i haven't had any problems...i forgot to mention that it was a Mobil 1 oil i changed to
Old Jul 4, 2007 | 07:16 PM
CIVICLUDE's Avatar
* B A N N E D *
ROYAL PURPLE STUFF!!!!!!!!!!
I LOVE IT
hondahead'
Nov 11, 2009 03:59 PM
vantta
May 26, 2009 06:28 PM
nihad
Jul 2, 2007 08:11 AM
THECRX
Aug 14, 2006 12:10 PM
JrCRXHF
Jan 9, 2004 09:24 PM
