Clunking from rear of car over bumps
Old Jul 3, 2007 | 08:14 AM
Jizzmaster Zero's Avatar
(banned)
Default Clunking from rear of car over bumps
When I go over larger bumps or speedbumps, I can hear a clunking sound from the rear of the car, might be coming from the passenger side. I just changed both rear shocks (gotta love those snapping bolts) and I also double checked to see that my exhaust was secure and not hitting anything. What could be causing the clunking?
Old Jul 3, 2007 | 08:19 AM
95ProjectEJ1's Avatar
Default Re: Clunking from rear of car over bumps (Jizzmaster Zero)
Are you lowered? Junk in your trunk (spare tire/jack no secure if applicable). Bushings on the LCA are in good shape? Nothing is loose underneath?
Old Jul 3, 2007 | 08:31 AM
fmrprojects's Avatar
Default Re: Clunking from rear of car over bumps (95ProjectEJ1)
check your shocks something is loose
Old Jul 3, 2007 | 08:34 AM
super_nguyen's Avatar
have you checked the condition of your rear trailing arm bushings? also do you have a rear sway bar, endlinks make clunking sounds when they are going out.
Old Jul 3, 2007 | 08:46 AM
specialized108's Avatar
do you have a systyem? maby your 2 12"s are moving more than you think they are like mine did
Old Jul 3, 2007 | 09:21 AM
(banned)
Default Re: (specialized108)
The LCA bushings are in great shape, I replaced 3 of the 6 when installing the shocks.
Spare tire and jack are securely mounted, not moving.
I have one 12 but the clunking is the same from before I had it
Car isn't lowered.
Shocks were assembled correctly.
No rear sway bar.
Trailing arm bushing are cracked here and there, but they still work fine.
Thanks for the ideas, keep em coming if you have more
Old Jul 3, 2007 | 12:08 PM
teal_dx's Avatar
Default Re: (Jizzmaster Zero)
could be rear wheel bearing. grab the tire like a big steering wheel and shake it violently. if it has any play then you need to replace the rear hub assembly. About a $75 part.
Old Jul 3, 2007 | 12:30 PM
(banned)
Default Re: (teal_dx)
No play in the rear wheel bearings either.
Old Jul 3, 2007 | 01:33 PM
pimpinblackcivic's Avatar
check the shock topmounts are torqued correctly and the spring properly seated
Old Jul 4, 2007 | 08:55 AM
(banned)
Default Re: (pimpinblackcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pimpinblackcivic &raquo;</TD></TR><TR><TD CLASS="quote">check the shock topmounts are torqued correctly and the spring properly seated</TD></TR></TABLE>
Check, they're fine too
Old Jul 10, 2007 | 02:34 PM
(banned)
It's still happening. I've isolated it to the right side of the car. When my left wheels go over a speed bump, no noise. When my right wheels go over a speed bump (right rear mainly) I hear a clunking, sounds sort of like metal bouncing up and down a couple times quickly, or being dropped and bouncing once after the first impact.
Old Jul 10, 2007 | 02:50 PM
del sol b18c's Avatar
my trunk latch is set a little high so i can push my trunk dorn about a quarter of an inch and when i hit a bump it makes a noise like that, it might also be you spoiler or rear bumper being loose. also if you get time please bump my thread "my car keeps cutting out! Why!!" i am trial and can't afford to bump and waste a post, if you have any input i am welcome to here it. thanks, hope you figure it out.
Old Jul 11, 2007 | 08:47 AM
teal_dx's Avatar
Default Re: (del sol b18c)
saw you just changed rear shocks, are the 2 top shock bolts tight, the ones that go into your fenderwell into your interior? I've had to re-torque those before after putting shocks in because they come loose.
Old Jul 11, 2007 | 11:32 AM
(banned)
Well funny thing is it was making the same noise with the old shocks, and they were torqued tight. I'll double check the nuts though, as well as the bumper and trunk latch.
Old Jul 12, 2007 | 10:09 AM
i still think the spring may be sitting slightly off centre too
Old Jul 12, 2007 | 10:13 AM
blaze_125's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teal_dx &raquo;</TD></TR><TR><TD CLASS="quote">could be rear wheel bearing. grab the tire like a big steering wheel and shake it violently. if it has any play then you need to replace the rear hub assembly. About a $75 part.</TD></TR></TABLE>
I ain't the starter of this thread, but you may have answered the problem of my gf's car
Old Jul 12, 2007 | 06:08 PM
(banned)
Default Re: (blaze_125)
Damn, I checked everything and no luck yet. When I assembled the struts/springs I made sure that both ends were seated correctly.
Old Jul 12, 2007 | 06:44 PM
slowcivic2k's Avatar
Check the compensator arm and make sure it is connected to the trailing arm and chassis, also inspect your XD XD XD XD trailing arm bushing... XD
Jizzmaster Zero.... XD what a splendid name... XD
Old Oct 20, 2018 | 05:32 PM
BeanRadman's Avatar
I have the same problem with my 2004 Honda CR-V did you ever find out what it was?
Old Oct 22, 2018 | 10:39 AM
Smoove910's Avatar
I'd say trailing arm bushing is going bad... I just replaced mine last year with OEM and it made a world of difference.
DawgC2
Feb 9, 2012 12:15 AM
acanby
Jul 10, 2011 08:01 AM
Nerv2g
30
Oct 24, 2003 01:09 PM
kek-san
Jan 2, 2003 09:17 PM
D.Lansing
Sep 15, 2002 09:58 AM
