headlight help! pics
Old Jul 2, 2007 | 09:18 PM
batzcivic's Avatar
Default headlight help! pics
please help the halo ring on my projectors burnt out..is there a way to fix it or did i get screwed into buyin a new set of headlights??
headlights
working halo
burnt out halo
thanks
Old Jul 2, 2007 | 09:41 PM
daluv's Avatar
Default Re: headlight help! pics (batzcivic)
Yeah man, you got screwed allright! If you really want some one piece headlights, check out TYC's, in my opinion they are ok looking in the black housing with the amber corner lense built right in, but thats just my opinion. Otherwise go back to your stock ones! Either way, with your stock ones or the TYC's, you wont have to worry about ricey halo's burning out on you! I'd think that if there was/is a way to fix your halo, its either...
A: going to cost you a nice chunk of cash
or B: ...refer to A.
Sorry about your troubles man. Hope all works out for you!
Old Jul 2, 2007 | 10:11 PM
CarbonizedDX's Avatar
Default Re: headlight help! pics (daluv)
If you run your halo's with your headlights they will burn out, the led's do not like the heat when they're on and this will burn them ou.......... Mine have been going for over three years only because I never have them on with my headlights.
I'd first check your wiring, it's possible that a bad connection had crept into the set up....
There are a few ways to fix the led's, some units you can actually pull the grommet out the bottom of the housing and it will in turn give access to a pull plug that holds the led's for the halo, I personally have only seen the type that are hot glued into the halo and you have to heat the headlight in an oven (200-275 degrees) to pull the headlight apart to then remove the halo to replace the led's.....
Old Jul 3, 2007 | 04:37 AM
batzcivic's Avatar
Default Re: headlight help! pics (CarbonizedDX)
if u dont run the halos with the head lights...then wen do u use them..the wiring is fine i did it myself 2 years ago...no problems untill now. so its burnt out for sure
Old Jul 3, 2007 | 07:24 AM
daluv's Avatar
Yuppers.
Old Jul 3, 2007 | 04:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batzcivic &raquo;</TD></TR><TR><TD CLASS="quote">if u dont run the halos with the head lights...then wen do u use them..the wiring is fine i did it myself 2 years ago...no problems untill now. so its burnt out for sure</TD></TR></TABLE>
I've got mine wired so they come on with the running lights and shut off with the low beams.
I found a write up on how to replace the led's but the pics are missing: LINK
Old Nov 10, 2011 | 07:46 PM
ponch15's Avatar
no more pics?
Old Nov 11, 2011 | 04:35 AM
Former User's Avatar
Old thread.
pliskin8
Jan 1, 2009 01:56 PM
mckrackin
Aug 1, 2006 09:54 PM
four-eyez
Apr 6, 2005 02:01 PM
Blacklightning
11
Nov 27, 2003 01:13 PM
555R
20
Jan 22, 2002 06:55 PM
