CRX will not start
Old Jul 2, 2007 | 05:45 AM
fonpee's Avatar
Default CRX will not start
I got a CRX wouldn't start after a bad backfire and a spark wire came loose while driving. I opened up the distributor and found out that the screw holding the rotor fell out. I put everything together and still wouldnt start. I think I might have flooded the engine while trying to start it. The cel is showing 1 because my o2 sensor broke off, which now just have a hole in the header. Any help will be appreciated.
Old Jul 2, 2007 | 12:11 PM
Efbluevtec's Avatar
Default Re: CRX will not start (fonpee)
try replacing spark plugs. need to get a 02 sensor back on there. or the computer will just keep on pushing more fuel into your engine. causing it to run very rich.
Old Jul 2, 2007 | 12:16 PM
SIred91's Avatar
Rainman
Default Re: CRX will not start (Efbluevtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Efbluevtec &raquo;</TD></TR><TR><TD CLASS="quote">try replacing spark plugs. need to get a 02 sensor back on there. or the computer will just keep on pushing more fuel into your engine. causing it to run very rich.</TD></TR></TABLE>
X2
If you have taken out and put your plugs back in at least once...thats your problem. You need to replace the crush washer EVERY time the plugs come out.
Old Jul 2, 2007 | 12:56 PM
89efDUSTY's Avatar
Default Re: CRX will not start (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">
X2
If you have taken out and put your plugs back in at least once...thats your problem. You need to replace the crush washer EVERY time the plugs come out.</TD></TR></TABLE> ? really, I have to be lucky I have pulled mine about 15-20 times and I never had to replace it.
Old Jul 2, 2007 | 01:40 PM
SIred91's Avatar
Rainman
Default Re: CRX will not start (89efDUSTY)
I have had this problem with soooo many hondas ........ Always check the crush washer.....This is mostly due to people over-torquing their plugs though....
I work on at least one a week with this problem....People coming in saying they keep popping off the plug wires.......lol
Old Jul 2, 2007 | 02:16 PM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">I have had this problem with soooo many hondas ........ Always check the crush washer.....This is mostly due to people over-torquing their plugs though....
I work on at least one a week with this problem....People coming in saying they keep popping off the plug wires.......lol</TD></TR></TABLE>hahaha ohh makes sense, I make sure to not overtorque it thats why...i learned the hardway before
Old Jul 3, 2007 | 05:49 AM
fonpee's Avatar
I just got new NGK v-power for it and it still does the same thing. I will try to get a better header because the stupid pacesetter o2 hole is at the traction crossmember and that's why the o2 broke off the first time. I guess I'll be looking for a obd0 b16 exhaust manifold/header.
BONNARSKI
Nov 2, 2012 01:44 PM
quad
20
Mar 14, 2007 05:16 AM
alpha
Nov 14, 2005 05:23 PM
itrhopeful
Jan 10, 2005 06:43 PM
nmeinc
Dec 18, 2002 09:35 AM
