FMU ?
Old Jul 1, 2007 | 09:25 AM
spotscivic's Avatar
Default FMU ?
which would be the best. and do i need to get a inline fuel pump??? and a pressure regulator? pictures help or somones prior expeirience.
Old Jul 1, 2007 | 09:49 AM
nsxmatt's Avatar
This is more of a forced induction question and one that has many topics if you search.
FMU's require a inline fuel pump for the high pressures the FMU uses. It's a skectchy setup and one that can be solved with many other fuel management options that actually allow of timing changes.
Old Jul 1, 2007 | 09:57 AM
Civicman86's Avatar
Default Re: (nsxmatt)
I would stay away from FMU's. They seem to work alright for low boost applications but like NSXmatt said, they are a bit sketchy. In todays times there are other pretty cheap alternatives for a much safer setup.
Old Jul 1, 2007 | 04:36 PM
spotscivic's Avatar
Default Re: (Civicman86)
like what?
Old Jul 1, 2007 | 05:10 PM
Crx Jimmy's Avatar
Default Re: (spotscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spotscivic &raquo;</TD></TR><TR><TD CLASS="quote">like what?</TD></TR></TABLE>
Like bigger injectors and a tune
Old Jul 1, 2007 | 05:28 PM
Syndacate's Avatar
Default Re: (Crx Jimmy)
FMU's and piggybacks are fine for like 60hp gains on boost.
If you wanna do it right ur best off getting Hondata s200 or chipping an OBD-I ECU, either of them can be tuned on a dyno, that's ur best bet for boost, dyno tuning = ownage.
b18sihatch
Mar 29, 2006 05:03 AM
Turbocivic94
Jun 1, 2004 03:04 PM
DXturbo
Jul 1, 2003 08:28 PM
SIK IN DA HED
Mar 15, 2002 09:13 AM
1.8EG-T
Sep 1, 2001 03:11 PM
