Searched and nothing helped .. IACV problem - please help
Old Jun 30, 2007 | 08:57 AM
EjSex's Avatar
Default Searched and nothing helped .. IACV problem - please help
I have a 98 DX with a b16a swap and an EX wiring harness...
when i first put the b16a in i was using a p73 computer (1.8L)
down the road i had to get rid of the p73 for a while and used a p2p (1.6L)
*when using the p2p the car would jolt back and fourth if i wasnt driving anywhere between id say 1k-2kRPMS and the car would idle fine unless i held the gas at around 1300RPMs it would sound like a dulled down 2-step and would purge...
i then got the p73 back and had no more problems
eventually i sold the p73 and put in a JDM GSR ecu (1.8L)
...noooooooooooo problems with the IACV again
then, i finally bought the correct ECU (P30) (1.6L)
and what do you know, IACV problem...
i ran the CEL check and got code 14 (IACV)
i checked the IACV and only one bolt was holding it on due to the fact that the bolt pattern wasnt wide spread enough so i came to the conclusion that it was the wrong one and after trying my friends LS IACV i realized that both 1.8L IACVs dont comply with my manifold...
^^THAT IS A PICTURE COMPARISON OF A B18 (BOTTOM IACV) AND THE IACV I RECENTLY BOUGHT THAT BOLTS UP TO MY MANI PERFECTLY (TOP IACV)
so i went ahead and ordered the wide bolt patterend IACV (the only other type) which was FOR my motor, and im still having the problem...
it strikes me as odd that with a 1.8L ECU i didnt have the problem but with 1.6L ecus i do have the jolting problem, even tho this time its the correct 1.6L ecu for my motor...
what could be the problem here? i dont know what else to try...
Old Jun 30, 2007 | 09:30 AM
EjSex's Avatar
bump, please help
Old Jun 30, 2007 | 10:45 AM
EjSex's Avatar
anybody out there?
Old Jun 30, 2007 | 01:18 PM
EjSex's Avatar
help please
Old Jun 30, 2007 | 02:02 PM
forcefedferio's Avatar
Default Re: (EjSex)
man i don't know, that is weird....if you already converted the car to obd1 then get a p28 and have it chipped with crome or something, you can shut the IACV off with it atleast that would fix the problem
Old Jun 30, 2007 | 08:44 PM
EjSex's Avatar
Default Re: (forcefedferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forcefedferio &raquo;</TD></TR><TR><TD CLASS="quote">man i don't know, that is weird....if you already converted the car to obd1 then get a p28 and have it chipped with crome or something, you can shut the IACV off with it atleast that would fix the problem</TD></TR></TABLE>
yeah it is weird ...id like to try to solve the problem before going to such measures but maybe thats my only option
can anyone else help?
Old Jun 30, 2007 | 10:49 PM
gourley's Avatar
Default Re: (EjSex)
bumppp i have the same problem!!
Old Jul 1, 2007 | 07:56 AM
EjSex's Avatar
bump, help would be nice
Old Jul 1, 2007 | 05:04 PM
EjSex's Avatar
hasnt fixed itself =\
Old Jul 1, 2007 | 07:05 PM
Paul*DC4's Avatar
Default Re: (EjSex)
bump, someone help this ******* kid!
Old Jul 1, 2007 | 07:11 PM
jonathan13's Avatar
Default Re: (paulwallnj)
bump for a sad sad situation.. ive been stumped like this plenty of times. good luck
Old Jul 1, 2007 | 07:20 PM
97Ej6mike's Avatar
It sounds TPS related. I had problems in the past with it jumping and sounding liek a two step, Turned out to be a fualty TPS that wasnt reading correctly at lower RPMs
Old Jul 1, 2007 | 07:34 PM
Paul*DC4's Avatar
Default Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">It sounds TPS related. I had problems in the past with it jumping and sounding liek a two step, Turned out to be a fualty TPS that wasnt reading correctly at lower RPMs</TD></TR></TABLE>
mad mike knows everything.
Old Jul 2, 2007 | 06:25 AM
gourley's Avatar
bump, paul stop posting worthless posts
Old Jul 2, 2007 | 07:22 AM
speedooo's Avatar
Default Re: (duheeat)
bill found a b16 iac at his house and its in my hatch at home. come to the meet tonight and well see whats up
Old Jul 2, 2007 | 08:12 AM
EjSex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paulwallnj &raquo;</TD></TR><TR><TD CLASS="quote">bump, someone help this ******* kid!</TD></TR></TABLE>
haha thanks
EjSex's Avatar
it also seems IAC and the fact that the CEL is for the IAC im pretty sure thats the problem =\
Old Jul 2, 2007 | 08:58 AM
Paul*DC4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duheeat &raquo;</TD></TR><TR><TD CLASS="quote">bump, paul stop posting worthless posts</TD></TR></TABLE>
bump, glad to see your posts were all worthy enough to help dylan's idle air control valve problem.
Modified by paulwallnj at 1:10 PM 7/2/2007
Modified by paulwallnj at 1:18 PM 7/2/2007
Old Jul 2, 2007 | 10:10 AM
leoaa777's Avatar
I would recommend you to pull the codes from the ecu. Just jump it and read the codes. It will tell you exactly what is wrong.
Should be a code 14 or so. Search around for the codes and what they mean.
Old Jul 2, 2007 | 11:20 AM
EjSex's Avatar
Default Re: (leoaa777)
it is a code 14 for the IACV but i cant figure out why its still throws the code!
Old Jul 2, 2007 | 07:21 PM
EjSex's Avatar
upppp
Old Jul 3, 2007 | 03:58 PM
EjSex's Avatar
bumppppppppppppppppp
Old Jul 5, 2007 | 08:03 AM
EjSex's Avatar
tttt
Old Jul 5, 2007 | 07:20 PM
EjSex's Avatar
upppppp
BootLip
30
Apr 12, 2011 03:49 PM
DrewMD
Feb 22, 2007 11:34 AM
wwang924
Aug 23, 2006 04:02 AM
91 HONDAsaurus rex
17
Mar 14, 2005 08:17 AM
