SWAP nightmare!
SWAP nightmare!
ok guys heres the scoop. I posted earlyer that i have a b16 freshly swapped into my eg. and i have no spark. I just discovered that i have no fuel either. I tested evrything on the distributer.( ECM, coil, tdcs, crank sensor.) and nuthin. I changed out my fuel main relay and still nothing. Im out of ideas and anything would help. Thank you.
im aslo stuck in sacremnto and i live in san francscio so please hepl me!
Re: SWAP nightmare! (jonezen1)
The ecm is one of the big common links between fuel and ignition. I would check the ecm connections and all grounds. Check the ecm fuse and, um, ok all your fuses. Check over any changed/added wires or wiring. It could be something as simple as a weak connection. Check for voltage at the injectors and ignitor(icm) while cranking.
If you have a Helms check the PGM FI troubleshooting flow charts.
sipolt89
12-09-2007 10:14 AM
