Earls Fuel filter ok to use?
i was wondering if it is ok to use this fuel filter? It seems really small and i've seen some people on h-t use it also.
i got this picture from another members thread but if you want me to take it off let me know
i was thinking of this one " http://store.summitracing.com/...w=sku "
what are the cons of running this small of a filter?
I've got a -4AN earl filter I got from summit. Works fine just had to get an adapter since I had -3AN oil lines. I heard there was somebody, maybe stan@fast-turbo.com that sells a -3an.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecallmotor »</TD></TR><TR><TD CLASS="quote">That filter is made for low psi. Its not meant for fuel injected setups.</TD></TR></TABLE>
the one pictures is for CARB APPS ONLY!!!!
if you go to http://www.anplumbing.com they have an EFI filter...its black and gold. I have one on my car. REALLY nice.
It works fine, i installed it in my car and im hitting 15 lbs and my afrs are dead nuts. In fact after switching to this style setup, my afrs where kinda rich at low rpms and low load.
I'm going to grab one of the Earls filters. They are good up to 75psi. The K20a2 operates at 50-52psi. It will be fine not to forget there are numerous people running these filters with no problems
you may want to look into a pleated filter. the one pictured can clog rather fast and need constant attention. a pleated filter has alot more surface area.
