in-line fuel filter
Old Jul 6, 2009 | 08:47 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default in-line fuel filter
i was just wondering what inline fuel filters people use inline with stainless fuel lines? are there any better or worse ones to watch out for?
Old Jul 6, 2009 | 10:12 PM
LurkerS8's Avatar
Default Re: in-line fuel filter
I use the -8an Earls filter, car makes 450whp with no problems.
Old Jul 7, 2009 | 01:29 PM
blackeg's Avatar
i used the -6 earls, 425whp no problems. i swapped it out for the summit brand -6 and i didnt notice and adverse fueling effects
Old Jul 7, 2009 | 01:40 PM
Bailhatch's Avatar
I like the design on the big aeromotive ones but have never had any problems with the smaller -6 earls stuff either.
Old Jul 7, 2009 | 01:46 PM
96 GSR-T's Avatar
Summit/Legs Brand without issues, -8 In/Out with a stainless mesh element, I think it was around $40
Old Jul 7, 2009 | 04:03 PM
thanks guys, i just remember reading awhile back that people had problems with certain inline fuel filters and i didnt want any problems
Old Jul 7, 2009 | 06:11 PM
96 GSR-T's Avatar
I got tuned with the wrong one on my car, I had an Earl's filter but it was for Carb'd apps it has a solid element and flowed like ****.
Old Jul 8, 2009 | 08:01 PM
would this one work (came on a car i had and it looks brand new
http://www.shopatron.com/product/pro...AER12316/415.0
Old Jul 8, 2009 | 08:30 PM
boostedcivicsir's Avatar
Mr. Badwrench
remember the larger the filter the more media to catch crap and still flow. 2 weldons here.
since im using a weldon pump,
weq1240 pre, weq1010 post.
http://www.weldonracing.com/product/..._Assembly.html
Old May 24, 2011 | 10:17 PM
young geezer's Avatar
what micron filter are you guys using? i keep hearing 10 micron is the best. what you guys think.
Old May 25, 2011 | 05:16 AM
lsturbo33's Avatar
Stock I believe is 7-8 micron. 10 micron is the best your going to get with the in line filters. Most of the smaller cheaper filters are 25-40 micron.
Old May 25, 2011 | 10:53 AM
what you guys think of this one. on the web side they dont explain what kind of filter it is and what micron size. does anyone know what micron size it is and would you recommend for people with over 400 whp? thanks.
https://www.chasebays.com/product/ho...--9401-integra
Old May 25, 2011 | 02:00 PM
B R Fittings's Avatar
The two filter brands that we use are aeromotive and fuel lab. If your going to be using E85, then we recommend the fuel lab 6 micron micro fiberglass element. Its compatible with E85, alcohol, and gasoline.
If your going to be only using gasoline then we use the aeromotive 10 micron fuel filter.
When your running a sumped tank, we recommend the fuel lab 75 micron ss element pre pump, and post pump we recommend either the aeromotive 10 micron (gas) or the fuel lab 6 micron (E85).
Old May 25, 2011 | 02:07 PM
MR.johnson's Avatar
-10 fuel lab still working great
Old May 25, 2011 | 03:23 PM
92redhatch's Avatar
Aeromotive
Old May 25, 2011 | 05:45 PM
FlewByU352's Avatar
I think the JEGS alcohol filter is 100 micron? I know thats not a small number compared to the others but honestly if you look at it, a piece of visible dust wouldn't make it through. Plus I always use Shell or American Aviation for fuel... cleanest stuff out there,
Old May 25, 2011 | 09:50 PM
The intank walbro pumps have a 35 micron filter sock. So there's no point in using anything higher then 35 microns.
75-100 micron filters are meant to be used pre pump.
Old May 26, 2011 | 06:14 AM
Muckman's Avatar
Moderator in Chief
I run the Russell 649000, -8 AN in/out, 10 micron. Yes it IS E85 compatible.
Old May 26, 2011 | 02:43 PM
Natural Aspirations's Avatar
Fuel Lab purchased through B&R
Old May 27, 2011 | 07:41 AM
[Ennis_D]'s Avatar
Earl's -6 35 Micron purchased through AN Plumbing here
Old Nov 26, 2011 | 05:46 PM
LS AzZkIkr's Avatar
Back from the DEAD! I am looking for advice as to where to mount my Fuelab inline filter. I am running out of ideas and hoping to get some input! Thanks!
Old Nov 27, 2011 | 01:08 AM
I have my fuel LAN filter mounted on the firewall.
It's not the prettiest arrangement but space was limited and it has easy access.
Old Nov 27, 2011 | 08:03 AM
Muckman's Avatar
Moderator in Chief
My filter is mounted in the fuel line tunnel under the car just forward of the fuel tank.
Old Nov 27, 2011 | 03:17 PM
LS AzZkIkr's Avatar
Thanks guys! That really helps give me some ideas. I always have always been told to mount the filter as close to the rail as possible. Is this true?
Old Nov 27, 2011 | 04:38 PM
digital sol's Avatar
just put mine on the back wall....easy to get to if needed to swap filters etc...not sure if its e85 compatible yet though so maybe switching soon...
