Ok, fitting size for BOTTOM of stock fuel filter...
Old Feb 15, 2002 | 09:58 PM
dustin's Avatar
Default Ok, fitting size for BOTTOM of stock fuel filter...
We have established the size of the fitting on the top of the fuel filter (-6AN to 12mmx1.25 pitch Earl's part number 991945), how about the bottom?
Dustin
Old Feb 15, 2002 | 10:02 PM
paulzy's Avatar
Default Re: Ok, fitting size for BOTTOM of stock fuel filter... (dustin)
one thing you can do is take off the fuel filter and go try out some bolts at the hardware store or some fittings at a local race shop....
one thing for sure is that it's a metric fine pitch...Most import brake line fittings are 10mm x 1.00 pitch, you can try that...
[Modified by Slow_ass_4dr, 11:03 PM 2/15/2002]
Old Feb 16, 2002 | 12:12 AM
dustin's Avatar
Default Re: Ok, fitting size for BOTTOM of stock fuel filter... (Slow_ass_4dr)
Well it is larger in diameter and wider thread than the top fitting on the filter...
Old Feb 16, 2002 | 09:01 AM
bigTom's Avatar
y do u need the bottom one?
Old Feb 16, 2002 | 09:52 AM
Suprdave's Avatar
Default Re: Ok, fitting size for BOTTOM of stock fuel filter... (Tom)
<--------was thinking the same thing...
If your running Braided line from the tank...then use an Aftermarket Fuel Filter with -AN Fittings.
Suprdave
Old Feb 16, 2002 | 09:53 AM
bigTom's Avatar
Default Re: Ok, fitting size for BOTTOM of stock fuel filter... (Suprdave)
Suprdave
exactly... or even if u are running fitting of s0ome sort then... run an aftermarket filter and lines
Old Feb 16, 2002 | 10:10 AM
dustin's Avatar
The aftermarket filters are expensive and do not have a cool mount like the stock one.
But... hmm... where are some good aftermarket filters? I saw the AEM one but I'm kinda trying to keep my car AEM free...
Old Feb 16, 2002 | 10:20 AM
bigTom's Avatar
get a paxton or aeromotive... those will add some points for ur "coolnes factor" fo sho b!
or u can get the sx filter which has a "cool" billet mount they make with it
u still need to add up more of those "coolness points"
Old Jun 23, 2004 | 02:30 AM
SuperTwinz's Avatar
Earl's P/N: 985006 (9/16th x 18) for bottom
Old Jun 23, 2004 | 02:33 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Ok, fitting size for BOTTOM of stock fuel filter... (SuperTwinz)
Holy 2 years ago batman!!
Old Jun 23, 2004 | 02:46 AM
SuperTwinz's Avatar
Default Re: Ok, fitting size for BOTTOM of stock fuel filter... (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">Holy 2 years ago batman!! </TD></TR></TABLE>Yeah, I was looking to see if 12mm x 1.25 thread is the same as 1/4 NPT and came up with that find.
Old Jun 23, 2004 | 03:03 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
LOL i just noticed
also FWIW K&N has a nice aftermarket fuel filter with a nice mount i have one for sale but maybe u got one after 2 years..
Old Jun 23, 2004 | 10:06 PM
Flamenco-T's Avatar
It is actually an M14 x 1.5mm, although the -6AN (9/16-18) shares the smae threads as the M14 x 1.5 up until about the last few threads of the threaded ends..
stan
Old Jun 24, 2004 | 12:20 AM
SuperTwinz's Avatar
Default Re: Ok, fitting size for BOTTOM of stock fuel filter... (Flamenco-T)
12mm x 1.25 is the same as a 5/16 NPT.
Old Jun 24, 2004 | 06:25 AM
Flamenco-T's Avatar
No, they're not the same. NPT are tapered, while all Metric are parallel. The diamater may be almost the same, but the threads definitely NOT..
stan
Old Jun 25, 2004 | 04:54 AM
Charlie Moua's Avatar
great info
Old Aug 4, 2004 | 12:30 PM
dustin's Avatar
Default Re: Ok, fitting size for BOTTOM of stock fuel filter... (Charlie Moua)
Glad I finally got an answer to my question, now that it's 2.5 years later.
Hehe.
Old Aug 4, 2004 | 12:40 PM
gritsak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">Glad I finally got an answer to my question, now that it's 2.5 years later.
Hehe.</TD></TR></TABLE>
you can finally finish your fuel system now
IntegraXTR
Jan 25, 2004 07:13 PM
turbo Si
Nov 26, 2003 09:59 PM
senpai
Jul 20, 2003 09:40 AM
turbo Si
Dec 27, 2002 01:27 PM
turbo Si
Dec 27, 2002 12:44 PM
