OBD1 conversion on the R
https://honda-tech.com/zerothread?id=199365
Check there.....usually its used so that you can put a burned proggie on...
I think so.. liek the current ECU is a bitch to chip/ play with.. so u gota get a jumper that connects the current one to the older obd... and then u mess witht he older obd
If somebody can host a pic for me I can post a dyno graph of what one of my ECUs along with one of my OBD2 to OBD1 ECU conversion harnesses did to my '98 ITR.
Email me if you can host a pic for me.
Dave, I think you already have it on the we todd did server.
-kenji
-kenji
Hey, I was thinking about converting to the OBD1...did you say you have a dyno of your car with it on it with just i/h/e setup? I have a 98 type r as well and was wonderin if it will be worth it.. I also have i/h/e setup... Thanks!
