not spark or gas
Old Jun 28, 2007 | 12:39 PM
slowassciv33's Avatar
Default not spark or gas
got a 93 civic non-v that wont start for anything. i cleaned the grounds checked the main realy tryed 3 different dizzys. theirs power to the dizzy but for somereason isnt reachin the wires. dnt say its the dizzy because i put it on another car and it started right up.WHAT ELSE CAN IT BE>????
Old Jun 28, 2007 | 01:06 PM
Default Re: not spark or gas (slowassciv33)
i need help dnt have a car
Old Jun 29, 2007 | 07:51 PM
slowcivic2k's Avatar
Check your fuses.....
Old Jun 29, 2007 | 08:57 PM
dannis.'s Avatar
have you tried new spark plugs? and does your fuel pump prime?
Old Jun 30, 2007 | 10:19 AM
Default Re: not spark or gas (dannis.)
nah the fuel pump doesnt prime..what fuse would i check?
Old Jun 30, 2007 | 11:48 AM
dannis.'s Avatar
the fuel pump relay.
Old Jun 30, 2007 | 12:01 PM
Linh.'s Avatar
Check the ground on thermostat housing.
Old Jun 30, 2007 | 12:20 PM
would the fuel pump relay be the reason for no spark?? already checked the ground by the thermostate thats the 1st thing i did
Old Jun 30, 2007 | 06:46 PM
dannis.'s Avatar
no it might be the reason why you fuel pump wont prime. but have you changed spark plugs like i stated earlier.
Old Jun 30, 2007 | 07:10 PM
93baggedcivic's Avatar
take the plugs out and clean them up.if your still not getting spark then it could be a fuse pinched wire.or the ecm.which no one wants to hear lol.same thing happened to my friends and it ended up being the ecm
Old Jul 1, 2007 | 04:04 PM
Default Re: not spark or gas (93baggedcivic)
where is the ecm located??
philztheone
Nov 5, 2014 10:28 AM
MrViet
Jan 4, 2010 07:58 AM
dan617
Feb 3, 2009 11:18 AM
dan617
10
Jan 31, 2009 02:10 PM
trav143
11
Oct 8, 2008 10:58 AM
