no fuel or spark help
Old Jan 31, 2009 | 02:04 PM
dan617's Avatar
Default no fuel or spark help
i was changing my starter and grounded it out now it will crank over but theres no spark and the fuel pump is not primeing or werking i changed the distributer and spark plug wires and changed the fuel pump ,the fuel pump only werks if i jump the main relay but still doest get spark i have checked all fuses and changed the ecu does any body have any idea wat the problem could be????
Old Jan 31, 2009 | 02:56 PM
fcm's Avatar
fcm
Old Fart
Default Re: no fuel or spark help
You have a blown fuse.
When you checked them did you test them with a meter or just eyeball them?
What is the MM&Y of the car? 94
Old Jan 31, 2009 | 03:21 PM
srmofo's Avatar
yup blown fuse, check them again....and next time unhook the battery when doing any electrical work
Old Feb 2, 2009 | 12:25 PM
mpls's Avatar
yep sounds like a blown fuses to me too
Old Feb 2, 2009 | 01:14 PM
so lazy's Avatar
Just as these guys stated you've blown a fuse.. I agree.. you're probably just checking the little fuses and just skipping the BIG ones.. like your Starter Fuse or your Battery Fuse. The battery fuse should range from anywhere in the 80 to 100. This is located in your Engine bay Fuse box not under your dash.
Old Feb 3, 2009 | 11:18 AM
fcm's Avatar
fcm
Old Fart
Pretty sure it's not a main fuse, engine would not crank if it was a main fuse. 94
nkerr09
Honda Motorcycles
Aug 3, 2017 04:24 PM
philztheone
Nov 5, 2014 10:28 AM
dan617
10
Jan 31, 2009 02:10 PM
slowassciv33
10
Jul 1, 2007 04:04 PM
blueR87
Aug 5, 2005 01:10 AM
