Camber kits
Old Jun 28, 2007 | 09:56 AM
BiggieBert's Avatar
Loved
Community Favorite
Default Camber kits
OK, I know there a lot of post on camber kits and I've read almost all of them. What I would like to know is, well first my setup 92 Civic Si, Tein Type Flex control master, stock wheels along with other engine mods. Ok the question, what camber kit would you recomend with this setup. I would do the washer trick but everything is ajustable so I just don't know some tips please.
Old Jun 28, 2007 | 09:58 AM
john666's Avatar
Default Re: Camber kits (BiggieBert)
random question.. how low is your car.?
Old Jun 28, 2007 | 10:01 AM
akunamatta's Avatar
* B A N N E D *
Default Re: Camber kits (john666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john666 &raquo;</TD></TR><TR><TD CLASS="quote">random question.. how low is your car.?</TD></TR></TABLE>
doesnt matter, i would reccomend skunk2 because they are cheap and have one of the best reputations.
Old Jun 28, 2007 | 10:03 AM
BlackoutVTi's Avatar
Default Re: Camber kits (akunamatta)
Ingalls front, washer trick back. Get an alignment. You're done.
Old Jun 28, 2007 | 10:22 AM
BiggieBert's Avatar
Loved
Community Favorite
As for the washer trick, its one washer per inch of drop, correct. Right now it's sittin about 1.5 lower. I forgot to measure the stock ride height so I don't know excactly.
Old Jun 28, 2007 | 10:28 AM
96hb's Avatar
Default Re: (BiggieBert)
You don't need no camber kit! My car is dropped almost 3" all around and all I did was the washer trick out back (3 washers for me) and got an alignment and its all good. Bought new tires almost 2.5 years ago and still got tons of tread on them and no uneven wear either. Probably put close to 40k miles on them so far. Camber kits are overrated and not needed in most, if not all, applications, IMO. But if you want to spend your money on one, either get Skunk2 or Engalls. They seem to have the best reputation.
Old Jun 28, 2007 | 10:39 AM
Default Re: (96hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96hb &raquo;</TD></TR><TR><TD CLASS="quote">You don't need no camber kit! My car is dropped almost 3" all around and all I did was the washer trick out back (3 washers for me) and got an alignment and its all good. Bought new tires almost 2.5 years ago and still got tons of tread on them and no uneven wear either. Probably put close to 40k miles on them so far. Camber kits are overrated and not needed in most, if not all, applications, IMO. </TD></TR></TABLE>
Translation: "I got lucky"
It's a cheap buy to just be cautious and get the ingalls and some freaking washers. But, whatever happens, I think everyone will agree that an alignment is a must after lowering a car.
Old Jun 28, 2007 | 10:45 AM
akunamatta's Avatar
* B A N N E D *
from what i've read the ingals front camber kit is inferior because it only allows adjustment from the top, reducing suspension travel on slammed cars.
the skunk2 pro series is a lower profile design that can be adjusted from the bottom. they rear camber kit is cheap, and offers full adjustment for fine tuning, why not?
Old Jun 28, 2007 | 10:46 AM
96hb's Avatar
Default Re: (BlackoutVTi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackoutVTi &raquo;</TD></TR><TR><TD CLASS="quote">
Well I must have real good luck 'cause I've never had a camber kit on any of my cars and tire wear was normal. Just got an alignment. Toe &gt; camber as far as tire wear is concerned.
Old Jun 28, 2007 | 11:03 AM
Default Re: (96hb)
Toe &gt; camber as far as tire wear is concerned.</TD></TR></TABLE>
This is definitely true anyway
As for the different brands, I suggested the ones that would be the least damaging to one's wallet, since the trouble of getting and installing one seemed to be an issue to the OP. I agree with the Skunk2 being a superior, more exact kit, but the Ingalls kit worked fine for me.
Old Jun 28, 2007 | 12:38 PM
aznguy0087's Avatar
skunk 2 or omni power got them for cheap just spend some money jizzz, and they look nice too YEAH!!!
Old Jun 28, 2007 | 12:45 PM
Agent_EM1's Avatar
Default Re: Camber kits (BlackoutVTi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackoutVTi &raquo;</TD></TR><TR><TD CLASS="quote">Ingalls front, washer trick back. Get an alignment. You're done. </TD></TR></TABLE> You beat me to it. Remember, tell the alignment shop to get the toe closest to ZERO.
Old Jun 28, 2007 | 12:48 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: Camber kits (Agent_EM1)
Meh, I've never seen it necessary on anything less than 3" for a front camber kit.
rear camber does need correction though.
I just can't justify spending money on either when the rear can be fixed to spec with washers and a bolt and the front is usually never the culprit of uneven tire wear.
Old Jun 28, 2007 | 02:13 PM
BiggieBert's Avatar
Loved
Community Favorite
Thanks guys. This is the first car I have built so. I appreciate all of the input.
00teg-gs
Suspension & Brakes
May 5, 2012 03:28 AM
HCivicSi23
22
Jun 27, 2007 07:47 PM
superdelsol
Suspension & Brakes
Dec 15, 2006 05:38 PM
blemar56
15
Dec 7, 2006 07:24 AM
tshaw
Dec 30, 2003 10:43 AM
