camber kits
Old Dec 29, 2003 | 10:09 PM
tshaw's Avatar
Default camber kits
I know this might be a dumb question but. I will be lowering my civic around 3 inches and when i install a camber kit how do you get it aligned (most places around wont align a car thats been lowered) and i always thought that the degrees was done by a computer when measured.
thanks
Old Dec 29, 2003 | 10:41 PM
lke2drvgsr's Avatar
Default Re: camber kits (tshaw)
what camber kit? if it's a camber kit that has easy access to the ***** to adjust the camber, then most shops will do it even if the car is lowered... yeah they use lasers to get the exact measurements in degrees to see how far off and they'll adjust it from there..
Old Dec 30, 2003 | 08:42 AM
onelowchef's Avatar
Default Re: camber kits (lke2drvgsr)
most any place will do a alignment, i just got one and my car is lowered. the only way they wont do it is if your car is too low to get up the ramps and on to the lift, the ramps are kind of steep.
Old Dec 30, 2003 | 09:02 AM
lke2drvgsr's Avatar
Default Re: camber kits (onelowchef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onelowchef &raquo;</TD></TR><TR><TD CLASS="quote">most any place will do a alignment, i just got one and my car is lowered. the only way they wont do it is if your car is too low to get up the ramps and on to the lift, the ramps are kind of steep. </TD></TR></TABLE>
nope they didnt do mine because they couldnt reach their fat hands under the wheel gap to get to the **** on the camber kit... but thats only cuz theyre dumb and theyre fat, i was easily able to do it
Old Dec 30, 2003 | 10:43 AM
mike1114's Avatar
you just have to find a shop that will do it or one that has a hole in the ground you can drive over instead of the lifts.
I have to drive all the way across town to this one specific action gator tire, they are the only people who will do lowered cars and they even tell you right away they will not offer a warranty because they might not be able to get it back to factory specs. My car isn't 3" lowered but they always do get it to the factory specs so no big deal even so, anything they can do to make the camber better is good.
Just a fyi, it is usually the toe on the car that will eat away the insides of your tires, not the camber!! My toe was off like 4 degrees, I went through tires in like a month.
BJA86
11
Sep 2, 2007 01:00 PM
guero2craze
Suspension & Brakes
Feb 22, 2007 09:53 AM
xstalkrx
Apr 24, 2003 05:37 AM
631 Teggy
Jan 18, 2003 07:38 AM
AxznBlitz
Aug 13, 2002 09:15 PM
