I got a few questions about timing belt/waterpump install
Old Jun 28, 2007 | 09:51 AM
zach1288's Avatar
Default I got a few questions about timing belt/waterpump install
I started my timing belt,water pump and tensioner last night. Everything was going well untill i broke a bolt that holds the water pump on flush with the block... How should i fix this? its hard to get up there because the frame is right in the way. Are those 6 bolts different sizes?
Also do you put lock tight on any of the bolts or the tensioner bolts?
Modified by zach1288 at 2:30 PM 6/28/2007
Old Jun 28, 2007 | 10:31 AM
zach1288's Avatar
Default Re: I got a few questions about timing belt/waterpump install (zach1288)
Bump...
Old Jun 29, 2007 | 07:56 PM
slowcivic2k's Avatar
If you torque them down right you should not need Loctite, Honda doesn't use it. The water pump bolts are all the same size.
Try to get a pliers in there and turn it out, your kinda on your own there...
ugaprof
Feb 13, 2015 09:36 AM
tacho95dc
Jul 16, 2007 09:10 PM
Cuong-nutz
Apr 29, 2005 01:20 PM
.RJ
Jun 18, 2003 10:57 PM
ten_30
Jun 6, 2002 08:38 AM
